Question about Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open? I have the same problem with my sentry 1610. I know the combination green lights are one but handle will not turn
  • 5 more comments
  • Anonymous Oct 09, 2008
    my sentry safe model 1610 won't open, the 5 digit code is accepted but handle won't turn
  • Waldmeister Nov 03, 2008
    exact same problem as stated by both other users
  • antennas2003 Nov 26, 2008
    same problem as mentioned door will not open
  • bobbili Dec 08, 2008
    I am having the same problem. Who can help us.
  • royj Dec 18, 2008
    same thing going on here. must be something with this model 1610
  • George Hoffman
    George Hoffman Jan 01, 2009
    same as everyone else... green light but will not turn handle
  • wyatthouse Mar 29, 2009
    We have the same issue - can it be a dying battery? We were able to open a couple of months ago.
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
  • pl8thed Feb 28, 2011
    Pushing up on the handle while entering the code was the trick. Turns out we had some paper jammed in where the piston/locking mechanism entered the safe wall. Thank you, hytman!
Yep, had the same problem - Two screws under the combo pad and replace the 9volt battery - Works like brand new!
Posted on Apr 08, 2009
I have everything important in mine. We tried and it would not open. We found that it had a battery and changed it. The the thing worked fine.
Posted on Feb 11, 2009
  • barbiedolljo Feb 11, 2009
    Change the battery. It's behind two screws under the combination. That fixed mine.
I HAD THE SAME PROBLEM ALL YOU NEED TO DO IS TO GET A NEW GOOD QUALITY NINE VOLT BATTERY!
Posted on Apr 22, 2009
Batteries did not help. so I had to tap the safe above the pannel. it opened. yes this safe is junk. I have this problem evertime i tried to open it.
Posted on Apr 14, 2009
Change the batteries.... I did and said "open sesame'" then the handle turned...
Posted on Apr 09, 2009
Same has the other guys have.got a 1610 sentry safe takes my combo light turns green. handel will not open ,
Posted on Nov 15, 2008
Just keep trying and it will open. i had to try like 20 times the other day and it finally opened. good luck because these safe's are junk !
Posted on Nov 09, 2008
3 Suggested Answers
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
Posted on Sep 27, 2008
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
How to fix a s0607
Jan 30, 2014 | Sentry Safe Qe4531 Firesafe Waterresistant...
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Safe codes
Sorry to say it's worthless. next time you see one charge them to haul it off.
Aug 24, 2008 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
2,394 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
