Question about GE WSXH208A Front Load Washer
Ge Frontload washer
The buttons on the control panel stick and sometimes require repeated pressing of the buttons to adjust the settings. How can I fix this?
  • 958 Answers
Sorry to inform you that you can not fix the buttons, they are placed between two sticky pads which are very hard to separate. replace the whole touch pad assembly.
tnx 4 using fixya,
drcool
Posted on Oct 09, 2008
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
Nov 25, 2013 | GE GFWN1100LWW Washer
I just purchased a GE frontload W/D set from a local chain retailer who didnt offer installation on the gas dryer that required conversion
Behind the knob on the control panel is a screw that needs to be removed to remove the control panel. Once removed, there is 4 screw around the door frame and two screw on the top of the front panel that needs to be removed to access the burner you seek. Converting to LP
Although this link if for a Whirlpool dryer, the burners and premise is the same. I hope this helps you, good luck.
Oct 10, 2013 | Dryers
KENWOOD KDC-215S HOW TO SET BALANCE
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Cheers,
Scott
Jan 21, 2013 | Kenwood KDC-215S CD Player
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
MY FRONTLOAD WASHER IS LIT UP CONTROL PANEL LOCKED I CANNOT DO ANYTHING WHAT CAN I DO TO FIX THIS
Please press and hold the end of the cycle button for 10 seconds and it will unlock the washer.
Mar 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How can i chage to ledge tray 2
Adjust the tray guides then confirm the size when the message comes up after the tray is reinserted, Then
  1. Press the [Log In / Out] button on the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
    NOTE: There are three unlabeled [Select] buttons located directly below the Display Screen that are used to select items on the screen. See the Related Items below for additional information on navigating the Control Panel.
  3. Enter the System Administrator LoginID using the numeric keypad, and then press the [Select] button to select 'Confirm'.
    NOTE: The default LoginID is 11111. If the LoginID has been forgotten, a service call must be placed.
  4. Press the [Select] button until 'Copy Settings' is selected, and then press the [Enter] button on the Control Panel. The Copy Settings 1 of 2 screen will be displayed.
  5. Press the [Right] arrow button on the Control Panel to display the Copy Settings 2 of 2 screen.
    the [Select] button until 'Paper Type' is selected, and then press the [Enter] button.
  6. Press the [Select] button until the required tray is selected, and then press the [Enter] button.
  7. Press the [Select] button until the correct paper type is selected, and then press the [Enter] button.
  8. If necessary, repeat steps 7 and 8 to set the paper type for another tray.
  9. When finished, press the [Log In / Out] button to return to the default screen
Aug 01, 2010 | Xerox CopyCentre C118 Copier
The screen on my Phaser 6360DN is to light to read, is there a way to adjust thee contrast?
On control panel press DOWN button to highlight "PRINTER SETUP". press OK. Press DOWN button to highlight "CONTROL PANEL SETUP" press OK. Press DOWN button to highlight "CONTROL PANEL CONTRAST" press OK then press UP or DOWN button to adjust. Repeat for "CONTROL PANEL BRIGHTNESS" if required. Press RETURN several times to go back to HOME screen
Apr 20, 2010 | Xerox Phaser 6360 Laser Printer
Panasonic CT-27SX12AF 27" TV The front panel controls/switches functions normally, but tv will not operate by remote (e.g. no power on/off, or channel/volume adjustments). However, if unplugged it from...
This sounds more like the connections at the IR receiver being bad. This module is located near the front of the set. While this is not the area of a large amount of heat, the area does heat up a bit. It is repeated heat/cold that will cause the solder to become a little brittle. It looks like the heat generated by the set running will end up breaking the connection. This is a simple fix that requires the removal of the PC board from the set. Without prior experience working inside TVs, I would not suggest you attempt this repair. This should be a labor only repair for any TV shop and should not take long to repair.
Dan
Feb 02, 2010 | Panasonic CT-27G11 27" TV
I am having trouble with the blue gun. It would
Be shure the guns are set properly follow below:
ADJUSTMENT PREPARATION:
  • Pre Heat Run should be finished.
  • Be sure Screen Color Temperature setting is in the COOL mode
  • Room Light should be minimal.
ADJUSTMENT PROCEDURE:
  1. Go to I2C ADJ. Mode. (With power Off, press the INPUT button on front panel and then press the POWER ON button then release. The Service Menu is displayed.)
  2. Set R DRV (COOL) to center data value (3F).
  3. Set G DRV (COOL) to center data value (3F).
  4. Set R, G, and B CUTOFF (COOL) data settings to [80].
  5. Adjust Screen VRs on Focus Pack fully counter clock wise.
  6. Choose SERVICE item [1] of I2C ADJ. Mode. Select CURSOR RIGHT and the Vertical will collapses.
  7. Adjust any Screen VR. Screen VR should be turned clockwise gradually until that particular color is barely visible.
  8. Repeat for the other two colors.
  9. Exit SERVICE MODE by pressing the CURSOR LEFT on remote.
  10. Exit SERVICE MENU by pressing the MENU key on remote.
Oct 12, 2009 | Hitachi 51F500 51" Rear Projection...
Keyboard lag
Sounds like you either have forward key sticking or you repeat rate in your keyboard settings is too high.
goto control panel -> classic view -> keyboard
First tab should be speed -> adjust repeat speed and try again. If that doesn't work then you have a key sticking and you keyboard may need to be cleaned or replaced.
Sep 06, 2009 | Dell 0Y3740 Keyboard
GE WSXH208A Front Load Washer Logo
66 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
