Question about Ricoh AC205L All-In-One Printer
Ricoh AC205L device not detected error
I have recently installed a new Ricoh AC205L MFP. After successful installation of the ScanClair 103 software on the client(s), some clients are not able to detect the device when configuring users/computers for the scanning option. I have ensure that the firewall on the affected clients is allowing the software to function correctly. The odd thing is, that even the clients that give me the "Device not found" error can still print to the device. Any ideas will be greatly appreciated. Thanks
  • gc34 Feb 10, 2009
    Yes, I have the same problem. Error for scanner but printer is good.?
I found that when I downloaded the scanclair alone and not the the Type 103 program and made sure the IP address was correct when asking to detect. Finally it detected it and was up and running.
Posted on Feb 10, 2009
WHERE CAN I GET A DRIVER FOR MY RICOH AC205 TYPE 103 COPIER PRINTER WHICH IS COMPATIBLE WITH WINDOWS 7
Hi, Here you can download the windows seven compatible driver for your printer Ricoh AC205L.Download from the below link. http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/ac205/ac205en.htm 1)Select the Operatin System and the PCL 6 is your printer driver.You can download other utilities also. 2)Hope the given information is useful to you. 3)Feel free to post your comments to correct my mistakes if any.
THANKS FOR USING FIXYA. BEST WISHES.
Dec 05, 2010 | Ricoh AC205L All-In-One Printer
HP 2727nf MFP software cannot be install through network
Are you installing SOFTWARE over network (i.e. from remote server) or you're installing your MFP over network? The latest means that you're installing software on your machine from CD/DVD/Image/etc and trying to connect to your MFP over network.
May 06, 2010 | HP Laserjet M2727nf Multifunction Printer
Error Message 103
I think it maybe because you haven't installed the "Driver" either at all, or properly. Uninstall any/all software. Reboot, DO NOT plug in unit. now, re-install the Software and Driver. Reboot, NOW plug in the unit, it should now be detected, and work.
You don't say what OS you are using? If Vista or Win 7, try installing as Administrator and also set Compatibility Mode for XP SP2 and run the main .exe as Administrator too.
Feb 12, 2010 | Digital Blue QX5 Microscope
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
appears only with a certain software
program or print job, contact the
software vendor for assistance.
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
My Ricoh AC205 Printer just blinked and turned off on its own - no light on the display panel. There was power on the cord. The 2 fuses visible when I opened the back panel are not busted. Any solution to...
I see you did not get an answer on the Ricoh AC205L problem. No power.....I have 4 of these machines with the same problem. Did you find anything out? Vendors want too much money for a board replacement. The machine would be a throw away and not recomended to buy Ricoh again, unless I can find a reasonable fix. (Component replacement, etc......)
Dec 22, 2009 | Ricoh AC205L All-In-One Printer
Ricoh Aficio MP 161 giving me an error code of SC670 and SC 980. It stops working all the time and I have to turn it off and back on.
One of the following controllers is
installed to the basic model:
* The controller of the MFP
model
copier/facsimile model
printer/scanner/copier
model
OR
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
Dec 04, 2009 | Ricoh Aficio 450 Copier
I dropped my blackberry and a jvm errror 103 error shows up
Contact your cell phone provider. They may have a solution for the error code. If restoring doesn't work, chances are it is a hardware failure
Apr 08, 2009 | RIM BlackBerry Curve 8310 Smartphone
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
MFP on.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Feb 17, 2009 | HP LaserJet 4345mfp Printer
Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 19, 2007 | Fujitsu fi-5650C Path-Through Scanner
Ricoh AC205L All-In-One Printer Logo
403 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
