Question about Acer Aspire 5002WLMi Notebook
Acer Aspire 5002wlmi Monitor
The Monitor has a black Strip about a inch wide going down the side, some time it will flicker and sometimes it's solid.
any suggestions on how to fix this problem?
Thanks
    Novelist:
  • 169 Answers
You first should check to make sure it's the LCD and not the video/motherboard. However possible, hook the laptop up to an external monitor (flat panel or CRT, either one will work). If the problem doesn't present on the external monitor, you have a bad LCD.
If the problem persists even on the external, you have a video/motherboard problem. Since most laptops have integrated video, the motherboard will most likely be your culprit.
Hope this helps :)
Scott
Posted on Oct 09, 2008
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
My digital flat panel sceen is 17 inches wide. but the display / desktop appeared is only 14 inches wide. my lap top is an Acer / Aspire 3690. thanks.
Your monitor is set to 4:3 resolution but physically is 16:9 wide. Change your resolution to a wide setting of 1280x800.
Jul 19, 2011 | Acer Computers & Internet
How to replace the DVD drive on Acer Aspire 5002
I actually had to permorm this action yesterday.
First remove the small strip above the keyboard by unscrewing the three screws at the back of the machine that hold it; then twisting the screen al the way back and lifting it up.
Second unscrew the keyboard (2 screws) and lift it away (don't detach the cable).
Third: on the left side under the keyboard unscrew 3 screws that hold the cdrom in place.
Pull the drive out. The rest (taking the case of the dirve) should be transparent.
There is nothing on the bottom you have to unscrew!
anthon@mnt.org
Oct 07, 2009 | Acer Aspire 5002WLMi Notebook
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Calibration sheet for Visioneer Strobe XP100 Part Number 85-0110-200
I made my own with a blank piece of paper and a sharpie. Make a solid black strip about 1.5 inches wide about 1.5 inces down from the top (short edge). about 1.5 inches below that make another one about 3 inches wide. Mine were at an angle but it still worked. feed it striped side down small line first. so esentially the first strip hits the entire width of the scanner all at once then it will see all white again, then all black again but wider this time. then all white till the end of the page. I based my mesurments on a picture so i have no real measurments but mine did work. if anyone has an actual page please take some mesurments and post them on here plz. well hope it works for you.
Apr 05, 2009 | Visioneer Strobe XP 100 Path-Through...
Acer Aspire 5610-4491
Check these people out.http://www.lcdparts.net/agnlaptopscreenbacklight.aspx?gclid=CMaln42tmZgCFQETGgodmUX5mQ
Jan 18, 2009 | Acer Aspire 5610-4491 Notebook
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Monitor Problem
This is probably the result of using the wrong display driver. It may even be set for an external monitor. If it was used with an enternal monitor, connect it up to the same one (or something similar) and use the display settings to get the computer to use the LCD as the primary.
Jul 09, 2008 | Acer Aspire 5002WLMi Notebook
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Acer Aspire 5002WLMi Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
