Philips convergence Ok - I have pulled both resistor 3156 and 3155 out of the board and after closer examination find that they are in fact the same 6.8ohm, 1w resistors as all the others. Both have been fried and that is why I didnt think they were the same. I tested both and they are dead. I replaced them both but still have the same problem with convergence. The centre of both the top and bottom of the screen 'bend' inwards and all colours are 'shadowed'. Do you know what may have caused both these resistors to burn out and what else I can look at? Cheers. Lukev
  • 8,617 Answers
The convergence ICs are what cause those resistors to fry, But its possible that others are also burned without any outward signs. They have to be checked by lifting one side of the resistors out of circuit.
Posted on Oct 11, 2008
The picture is blurry and there are red lines in all programs mainly on the right side. advanced convergence doesnt work and when i use my dvd player the red lines are everywhere
You have several bad grounds in the convergence board. This TV will also need a new convergence IC. I believe it is a STK 393-110. It has poor grounds on its pins to the circuit board. I would suggest you replace it with a new one, it would be heart breaking to resolder the original IC and discover it is bad. It takes quite a while to pull this board out and replace. Be sure to check the 2 watt less than 10 watt resistors too. They can be bad. And I cannot tell you enough...there are also many,many bad grounds through out this convergence board. Please really examine this closely. Solder any and all ICs attached to heat sinks, power resistors, transistors, transformers etc. This TV is worth repairing. Thanks for asking and show a few hands of support!
Mar 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
Convergance Problem Troubleshooting
check resistors 3149 through 3160 they are 6.8 ohm 1watt 5% metal film resistors
Jul 19, 2008 | Philips 43PP9202 43" Rear Projection...
Replaced Convergence IC's and now no power
is this a typo-replaced Stk392-120 with Stk394-160 because you cannot interchange to that number IC you can go to a STK392-160 also you cannot check resistors in circuit because you will get the resistance from the circuits around them you have to lift one leg out of circuit to test them.if you need further help or further information pls let me know
May 05, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence Board
Have you tried just replacing the STKs? This set uses two STK392-120s I think.
Dan
Mar 18, 2008 | Philips 51PW9303 51" Rear Projection...
Jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Mar 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Burnt resistors
Researching resistors---
What caused the resistors to burn?? Have you already fixed
that? If so, what exactly was it ???   let me know...T.
Oct 18, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
