When the computer is booting up hit F8 until the screen comes up that allows you to select "safe mode". When you enter computer in safe mode you can go into "user accounts" and either delete the password all together or reset it. You can even create another user account if you want. Please let me know if this was helpful.
Well..there may be a password hint installed that you can figure out..otherwise..it is not attractive options
3. From the center screen, select your encryption type from under the Security Options heading.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
hope this helps
