Question about Whirlpool Duet GHW9150P Front Load Washer
Need to buy drain pump
Whirlpool duet washer ghw9100lq, need to buy drain pump, after cleaning out the bottom of filter, pump only works some times. where is the best place to purchase
  • 5,911 Answers
I have found searspartsdirect.com to be the best source for purchasing parts. Just type in your model number and the pump will be located under the "Pump and Motor" heading as item number 10 (part #8181684). The Sears website also has helpful exploded view illustrations that you can use for troubleshooting and component identification. For comparative pricing, repairclinic.com also carries many of the same parts. Use the part number provided by Sears for your search. This is the easiest way I know of to order parts and have them shipped directly to you. This generally isn't a standard part that an appliance repair retailer would carry in their inventory, I hope this helps answer your questions. If you need assistance in installing the replacment pump, go to my profile and look under my "Tips and Tricks section. I have a write up on step-by-step instructions for replacing a pump on a Whirlpool Duet and Kenmore Elite front loader.
Posted on Oct 09, 2008
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Clothes don't spin dry enough
you mean to say the clothes are tangled with each other tightly right?
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a GHW9100LQ front loading Whirlpool Duet washer that is 7 years old. It has recently been displaying error code F02. Today water leaked onto my floor. I read the suggestions on cleaning the drain...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Whirlpool GHW9100L Front Load Washer
I need to clean the lint filter on my whirlpool duet front loading washing mashine. where is it located and how can I get to it?
Its not really a lint filter ,it catches everything that gets down to the drain pump.You need to remove the lower panel on the front of the unit(three small screws one on each side and one in the center down at the floor) pull out bottom of panel to axcess the drain pump. MAKE sure to unplug before working inside.drain pump will have two hoses running to it ,to clean out the filter (trap) turn the cap facing you to the left to remove some water will drain out have a towel to catch reinstall everying in reverse order .sounds like a lot but is actually very easy after the first time
Aug 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is saying f2 what does this mean
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How can you tell if the MCU is not working
Unplug the power cord.
First you need to remove the lower panel on the front of the washer and clean the drain filter.(3 screws)Turn the filter counter-clockwise and pull it out.
If the water does not drain in the correct amount of time the washer will not enter high spin.
Second, the MCU is a common failure on these machines. The motors seldom fail.
Third,check all wire connections to and from the MCU for loose,broken or corroded. All 3 circumstances can happen.
Jan 17, 2010 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
274 people viewed this question
Dan Webster
Dan Webster
Sal De
