Question about Panasonic CT-32G14 32" TV
Panasonic TV picture shrinks to a line
This is a 8 year old TV. The picture shrinks into a line. It degresses over a few minutes. The sound is fine. Sometimes it is a few minutes sometimes it is a half hour. This has happened to two tvs in this area. They are powered through a surge protector.
  • popcat33 Oct 09, 2008
    It makes sense because popping on the side is what I did with the TV to make it work. i am not handy with a soldering iron so I will have to have a repair person do it. However , I know how long it should take and how much it should cost.
    Scholar:
  • 92 Answers
There is an IC which controls the vertical deflection and over the course of a few (or 8) years with the set heating up and cooling off some of the connections work their way loose causing the symptoms you describe.
If you were to bang on the side of the set you could likely "pop" it back in but this is not a good solution. The vertical IC needs to be re-soldered. This is especially common in Panasonic sets. About 10 minutes with a soldering iron should have it worked out.
If you're handy with a soldering iron I can tell you what to look for.
Posted on Oct 09, 2008
  • Panasonic Master
  • 19,396 Answers
That means that one of the convergence ICs is faulty.
Insignia tv sound but no picture
At 8 years age components are wearing out. It sounds like a power supply issue. It is not cost effective to repair.
Mar 26, 2014 | Insignia Televison & Video
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
No sound, and no picture today. Everything was fine yesterday. 3 years old
is the tv a rear projection if so it the bulb you will need to replace it
May 30, 2009 | Panasonic Televison & Video
Picture is there briefly then goes black with sleep timer blinking
your tv had a cold solder,so try to resolder the vertical ic. or vertical section as well.
Sep 05, 2008 | Sony KV-35S42 35" TV
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Panasonic CT-32G14 32" TV Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
