Question about Boston Acoustics Competitor 1200 Car Subwoofer
Subwoofer shut down
I have a 2006 Dodge Charger with a Boston Acoustic 6-speaker system. When I turn the volume up on a song with a fair amount of bass, the rear speakers shut down. The front 4 speakers work fine. I have taken it to the Dealer but they claim they cannot replicate the problem and basically ignore me. Is there some sort of resistor that is causing the rear speakers to shut down?
    Scholar:
  • 92 Answers
The amplifier probably has a built in protection circuit to keep from over driving the subwoofers. This will prevent the dealer from replacing woofers........most likely it's designed to be overly safe.
There's likely not much you can do about it, if there's not enough bass you may have to seek out a larger amplifier.
Posted on Oct 09, 2008
Loud humming sound
Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
Acoustic reaserch subwoofer dont have any sound
If this is a powered sub then it's most likely the internal amp inside it that has failed. It's more than likely the part that works the hardest on the board. IE the main amp semicoductor.
Dec 19, 2012 | Boston Acoustics Audio Players & Recorders
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
I have boston acoustic speakers ba735 how do I hook them to my pc
if they have a usb connection or a 3.55mm plug plug it into the required outlet then control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
Oct 01, 2010 | Boston Acoustics BA735 Computer Speakers
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Feb 18, 2008 | Boston Acoustics BA7500 Computer Speakers
Boston Acoustics Competitor 1200 Car Subwoofer Logo
123 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
