Question about Canon PIXMA MX310 All-In-One Printer
Canon pixma MX310 scanner not working
Hi, I have a brand new machine, and the scanner will not work.  Printing and copying are fine.  Thanks! M.
  • 6 more comments
  • AO123 Oct 13, 2008
    I am getting an error : Cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. Scanner driver will now close. Code : 2,155,0
  • smoove1010 Oct 18, 2008
    My brand new Pixma, right out of the box, behaves the same way. Printing works fine as does copying. Occasionally I see part of the image while doing a scan preview, then the image disappears, and I get the error. My previous scanner (Lexmark) worked fine, but the printer was broken, hence the new purchase. Thanks in advance!
  • Anonymous Nov 15, 2008
    behaviour like described while scanning
  • Anonymous Jan 05, 2009
    Same thing, same error message. Were you able to get this fixed?
  • mexicogal Mar 14, 2009
    Installed a new modem and the scanner won't work.  Re-installed the scanner from the disc but still is not working.  What can I do?    J.
  • xarob Apr 05, 2009
    Same problem, error code 2,155,0 printer is connected with PC by means of USB cable 5 meters of long.
    Could this be the problem ??
  • Anonymous Apr 06, 2009
    HOW CAN I FIX THIS
  • Anonymous Apr 22, 2009
    Solution #1 is the best. It solve my problem and save me time.
    The MX310 printer does not work for network scan. It works only if you directly connect the printer to your computer via a USB cable.
    Thx
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Posted on Feb 25, 2009
    Problem Solver:
  • 4 Answers
Scanner do not work
Posted on Feb 20, 2013
Hello. I have an solution of this problem! I had the same problem. The nonworking scanner problems are :
1. a USB cable too long (after 1 meter)
2. if the cable is connected throught a USB hub
3. if you didn't install the software correct
4. Windows (xp/vista) sais that the printer you had connected into the computer is not recognized
How make it work:
in case 1. buy a USB cable that is shorter that 1 meter (the last variant to choose0
in case 2. connect the USb direct into the computer
in case 3. inninstall the software and install it (make sure that the antivirus and the internet and other programs are closed; install cd 2 too)
in case 4. put the USB in other USB connector
Then the scanner must work!
Posted on Apr 08, 2009
  • costin_l05an Apr 08, 2009
    PS: If the computer still saing that "cannot comunicate with scanner" do this:
    1. umplug your printer USB from computer then plug it 3 4 times (you must to hear a sound that confirms that the printer is in or out)
    2. turn off then on your printer
    3. connect disconnect your AC Power
    4. rester your computer
    5. connect the USb
    6. restart it again
    7. start scanning
    Now it must work....
    Posted by xarob on Apr 05, 2009
    Answer: Yes, this is the problem.
Canon MX310 wihn check printer message 6000
Had the same error message with Pixma MP560 (Tried to colour copy)
Turned off and on - no success
Turned off open the printer
Turned on
Copied black&white
Everything works fine
Thanks
Ben.
Jul 05, 2011 | Canon PIXMA MX310 All-In-One Printer
Cannot receive fax. It goes into memory. LCD reccomends new B-CRT regarding my Canon PIXMA MX310 printer . No problem sending fax,copying or printing.
B-CRT is just asking for a new black cartridge, fax will not print until it's replaced so you don't get a partial fax that you can't get back after printing.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 sacnner not working (mac)
Use Spotlight and search for MP Navigator or look in Applications>>Canon Utilities>>MP Navigator
Sep 30, 2009 | Canon PIXMA MX310 All-In-One Printer
U163 - I have ink cartridges... been working fine!
Shut the printer. Take the cartridge out.Clean the area with a q-tip ot paper towel and put it back in and restart. The cartridge is not communicating with the machine.
Jul 21, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 scanner
I know i have the same problem
This is how you get around
sorry the scan button is useless but what you can do is fing the scanner and camera wizard on your windows computer and it is selfexplanitory from there
Jan 28, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310-cant even figure out how to copy!
Canon PIXMA MX310 Office All-In-One Printer User Manual
here you go here is the manual for your printer hope it helps and thank you for using fixa
Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
4,550 people viewed this question
old marine
old marine
