Question about Ovens
Pressure of flames in Cannon gas oven
Oven is igniting and staying lit but, flame stays low. Generally when control knob turned up the flames go high and you can hear it. Therefore, not much heat in oven and cannot cook anything as not getting hot just warm.
Is this the thermostat? If so, how do you change it and where is it best to get a replacement part?
  • scotvic88 May 17, 2009
    is the igniter then main flame supervisor valve or the gas burner body?
  • 943 Answers
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
Gas either ignites or it doesn't. What are you talking about?
Posted on Oct 29, 2011
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
My ovens wont stay alight i have a twin range gas oven and it just wont stay lit but if i hold the knob in it stays lit
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
: I offer free advice bcuz God is so good!
Jul 31, 2011 | Belling Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
Ovens Logo
842 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
