Question about RCA HD52W59 HDTV Projection Television
HD52W67 Replacement Parts
I have a HD52W67 rear projection tv. The only thing that was missing when I got it was the frame that holds the plexy glass in front so the picture will show. Does anybody have one that they don't need or want to get rid of?
  • 61 Answers
Pls check with andrewselectronics.com with model number you can find toll free number to talk with representative..
Goodluck
Dals123
Posted on Oct 09, 2008
How do you remove the screen frame to remove broken glass? Can the glass be replaced with a piece of plexi glass?
hello am rico, no you cant, unscrew all the screws from the back and bottom front. should be able to open it. if you need more help let me know. 602-810-7149
Jan 07, 2011 | Sony KP-51HW40 51" Rear Projection...
Every thing on the tv is mostly blue
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 20, 2009 | Hitachi 51G500 51" Rear Projection...
Where can i get the plexie glass cover for a toshiba 51hc85 and can i just use any plexie glass
The screen is available using part number: 23311065 for $52.58 plus shipping. This cost was from tritronicsinc.com (a Toshiba parts distributor.)
Dan
Oct 26, 2009 | Toshiba 43A10 43" Rear Projection...
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Outer screen gouged on mitsubishi vs-55609
How were you able to remove the plexi glass screen? I have the same problem, but I don't know how to remove it!
Jan 17, 2009 | Mitsubishi VS-55609 55" Rear Projection...
Broken front lense
It depends on whether the lense has a textured finish molded into it; most do.
It it does, you cannot replace it with clear plexiglass.
Jun 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
My tv
if your tv has black borderaround screen protector it has to be replaced with original part..if not it can be replaced with plexi-glass, avail at local home improvment stores john
May 24, 2007 | RCA P52926 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
283 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
