Question about Goodman Heating & Cooling
Wiring diagam for goodman heatpump and air handler to thermostate
  • musiclover07 Oct 09, 2008
    I need a wiring diagram for goodman air handler and goodman heat pump to a heat pump thermostat.
    Scholar:
  • 121 Answers
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
My goodman ac unit. M#g8x130301bd comes on with the thermostat turned off when i turn thermostat to cool the fan on the air handler wont come on
Incorrect low voltage wiring, or if the wiring is old, most likely a break in the insulation of the wiring creating a short.
First thing, check the wiring diagram to see that all wire colors are attached where they should be at the thermostat.
Then look at the wiring diagram at the air handler and verify the control wires are on the proper terminals.
Apr 05, 2016 | Goodman Heating & Cooling
Wiring diagam for a model number febb-015ha heater
there should be one on inside of air-handler cover or electrical box cover.
Aug 22, 2015 | Heating & Cooling
Intermittent 24v short on heatpump
check the thermostat wiring as it passes through the air handler and condenser sections. If the wiring has been rubbing against metal the insulation may have worn off exposing the copper wiring.
Jul 17, 2014 | Goodman Heating & Cooling
I need to know where on a goodman heatpump the transformer is located?
The transformer is located in the air-handler which is the indoor unit., ore than likely it is a blown fuse.
Oct 14, 2012 | Goodman Heating & Cooling
Blower will not blow air with cover on unit when i take cover off air blows through vents on package heatpump
Sounds like return air supply clogged, check filter and duct work also some units have a filter at air handler at bottom some time the installer leaves them in
Jan 03, 2011 | Goodman CLQ36AR49 Air Conditioner
I have a Goodman condensing unit that freezes up occasionally during low ambient weather (20 F). Model # ssz160361ac with matching new air handler. I have adjusted the defrost time from 90 to 30min. This...
It is not freezing up because of the temperature, but because of ice being formed in inside. Either by a blocked condensation duct, or snow due to previous storm.
Jan 31, 2010 | Goodman Heating & Cooling
THE AIR HANDLER IN SET IN 75 DE GREE, THE CONDENSING UNIT GET OFF BUT THE A/H IS RUNNING AND DON'T STOP UNTIL THE C/U START AGAIN Y GET AGAIN THE 75, MY SYSTEM IS A 5 TON 12 SEER BOTH ARE INTERTHERM
1 Do you have a digtal thermostate?
Do you have GAS ELECT OR HEATPUMP
All of the fan setting have a dip switch so the fan can be set to match
the type of heat you have
2. is the fan switch in the on poision
Oct 28, 2009 | Intertherm Heating & Cooling
Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
Oct 27, 2009 | Heating & Cooling
My goodman air handle is run on e-heat only and will not turn off ,also the outside unit will not turn on , I put a new themostat this didn't help I have a goodman heatpump
Heat-Pumps can be temper mental. Sounds to me like your air handler is running on emergency heat, due to a problem with the condensing unit.You have heat strips in the air handler in case the outdoor temp. gets to cold and the heat pump cant keep you're home warm.Also, if you loose a compressor, it will go into emergency heat. If you have lost the compressor for one reason or another, lets say a locked rotor, the compressor would draw L.R.A. (Locked rotor amps) and cause the circuit breaker to trip. Check this.As for the air handler running all the time, you said you replaced the stat? When you removed the control wiring from the stat, did the fan shut off? I wish I were on site to help you, but all I can do is offer you some advice. With the power off to the air handler, go to the stat and remove the red and green wires. Turn power back on and see if it stops running. If it stops, then it sounds like the new stat is also faulty? If it continues to run, check the wiring in the air handler to make sure the red and green are not touching somewhere, and also check the control wiring on the outdoor unit for the same problem. Do you have any dogs that may have chewed into wiring? If so, check all outdoor t-stat wiring. There are so many things it could be and I hope very much I have helped you with solving this online, which can be difficult. You may also have a faulty defrost board. Try to do what I have asked of you.
Good Luck, Sincerely, shastalaker7
Oct 16, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
1,659 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
