The door seal needs replacing. Can I do this myself and does one need any special tools?
Normaly you get at it from above by taking the top of and undoing the band fastening it to the drum outer,on some makes it could be from below,it can be a fiddley job dont forget to turn power and water off.goodluck
Posted on Oct 09, 2008
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Stalled, leaking gas on drivers side by the rear door, i believe its a fuel pump? 2003 ford expedition. Can I replace it myself?
I replaced my filter on my 2003 also but you dont need special tools, you just squeeze the tabs on the connectors and pull them off. you might have an o ring missing on the one of the 3 hoses on the filter. The filter is under a plastic cover by the fuel tank near the driver side rear door.
Jun 22, 2009 | 2003 Ford Expedition
Oil seal leaking on 1999 gmc half ton 4w/d on front of transfere case do i need special tools or can I drop drive line and replace seal
billbohman: Unless GMC has had some change I am not aware of and that has not been published in service manuals for the repair of these units, the procedures are the same as any seal replacement and require no special tool. There are some universal seal installation tools which I would venture the majority of techs don't have because they substitute other tools in their place most of the time. Most techs will have a special tool designed from removing seals. However, the seal can be removed without it.
Just use a little common sense when removing a seal. Don't damage the casing.
Good Luck.
May 10, 2009 | GMC C1500 Cars & Trucks
Passenger power mirror, how to replace it?
you need to remove the door panel ,to install mirror assy-tere are no special tools(10mm socket,ratchet and #2 phillips screwdriver)3 nuts hold the assy. to the door and the connector is easy to see,there are no special sealers needed(seal is already on mirror assy)good luck!
Nov 14, 2008 | 2002 Mitsubishi Galant
I have a LG front loader washer model wm-2032hw. The seal around the door is ripped on the bottom and is leaking on the floor. Would I be able to replace the seal myself? How difficult would it be?
You need to remove the spring loaded wire from around both sides of the seal. The back one is accessable after you remove the front side of the seal. LG does make a special plier (actually, one plier for the front, a different one for the rear) to spread the spring apart to aid in removal and reinstallation, but you can do it without the special toolls with a little effort. On a scale of 1 - 10, I would rate it a 3. Go for it !
Sep 20, 2008 | Washing Machines
Drum bearings
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
Aug 19, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Driver's side window regulator
I just replaced the regulator in my mother's 98 civic ex and didnt need any special tools. I do recommend replacing the glass run channels on either side of the window. I have replaced the regulator twice and it is still having problems as I haven't replaced the run channels. If not replaced very soon I can see myself replacing the regulator...yet again!
Aug 04, 2008 | 1998 Honda Civic
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Door seal wire spring replacement
oh my there is no way but to take front off and you need special tool to hold the spring in place this may a job for a tech IT IS NOT FUN!!!! but there is NO WAY to put spring back on Trust me Ive tried Good luck
Dec 17, 2007 | Frigidaire GLTF1040A Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
