Question about Freezers
Kenmore commercial standup freezer alarm
Alarm will not shut off even after quick freeze or alarm off button
  • 1 more comment
  • tmacdaddy Oct 31, 2008
    I have the same problem. The alarm goes off and I hit the reset button - to no avail. It flashed 0 degrees and then a 6 degrees... I figured maybe the freezer was warming up - but there is no way I can find to make it colder...its driving me crazy.
  • mikeeirish Nov 06, 2008
    Is there a way to just disconnect the alarm??
  • Anonymous Apr 15, 2009
    the door open alarm wont go off its driving me crazy
Sounds like the temp sensor is bad or intermittant. Check the connections to the display to see if they are loose. If not, the sensor might be bad, causing it to read the wrong temp. The fact that it is jumping around like that points to this kind of problem.
Posted on Feb 11, 2009
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Jun 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The alarm keeps going off. Food is frozen fine just alarm
That alarm is there for a reason. Grab your owner's manual and see the different things it can mean. If the gas is getting low, that could be it, and you'll want to solve it as early as you can.
Sometimes a power surge or brown out can make that alarm go off. Try unplugging it for 5 minutes.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer
Control is bad and needs to be replaced. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 20, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Freezers Logo
654 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
