Question about Boston Acoustics MicroMedia Computer Speakers
Power Unit Question
I have Boston BA 635 speakers but the power unit is toast. Where can I get another one?
Perhaps your part is available at http://www.bostonacoustics.com/OrderParts.aspx.
Try and enjoy!
Samagora
samagora@yahoo.com
Posted on Oct 24, 2008
I have boston ba 735 speakers i am using a new pc with windows 7 a presonus firemobile setup. I can get no sound out of the boston speakers. They are lit up when connected. I am able to record sound via...
click start control panel hardware and sound manage audio devices playback then select speakers you will se a list configure test disable set as default show disabled show diconnected.right click on speakers make sure they are enabled also select the recording tab you will see microphone midi right click on microphone and midi make sure ticks are in boxes show disabled devices and show disconnected devices
hope this helps
Jun 27, 2011 | Boston Acoustics BA735 Computer Speakers
BA 635 subwoofer stopped working. green light in the back does not light up anymore. Can it be the power supply cord? It this common? Solution? How can I check if it is a power cord issue?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 27, 2011 | Boston Acoustics BA735 Computer Speakers
I am looking for a power cord for the BA 735 speakers
Attached is a link to a list of Boston Acoustic speakers a/c adapters. You will just need to model number of your adapter to find the correct one. These items are listed on Ebay. Ebay generally offers the most cost effective option for purchasing items like this.
http://shop.ebay.com/i.html?_kw=power&_kw=Boston&_kw=Acoustics&_kw=adapter
I hope you found this helpful, if so, please remember to leave positive feedback.
Thank You,
Brian
Feb 10, 2011 | Boston Acoustics BA735 Computer Speakers
Boston BA7500G Speakers with no sound.
Well we have eliminated the laptop as a problem,.. that is very good. As far as what the problem with your BA unit is,.. we only know that it does not function with an external device (laptop and mp3 player). you already mentioned that a sound test from the unit plays through all the speakers,. right? With that lets start with the most basic item that will cause this problem,.. the cable that comes from the BA unit and plugs into the laptop or mp3 player. Is the cable plugged into the right place on the BA unit? Does the cable disconnect from the the BA unit? if so, do both ends of the cable look the same or is there 2 ends (maybe red and white) that plug into the BA unit? Please let me know when you can and we can continue troubleshooting this.
Feb 08, 2010 | Boston Acoustics BA7500 Computer Speakers
No sound
Try plugging in earphones to see if the problem is the speakers or the output from your computer. Also, your computer output may be low power output for powered speakers and your speakers are not compatable. You may also be plugged in to the wrong output on your computer.
JG in AZ
Apr 11, 2009 | Boston Acoustics BA7500 Computer Speakers
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
No power to my subwoffer
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
Feb 09, 2009 | Boston Acoustics BA7500 Computer Speakers
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
I lost my adaptor for Boston BA 265 Speaker, 12 V in but What amp
Do not worry about the milliamp.
As long as you use an adapter thats the correct voltage (you stated 12 volts), the end connector fits into the speakers and the polarity is the same, then you wont have any trouble.
Jan 11, 2009 | Boston Acoustics BA265 Computer Speakers
Boston Acoustics MicroMedia Computer Speakers Logo
80 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
