Question about Jane Powertwin Azulon Stroller
Jane Powertwin - back wheels splaying?
We have a problem with our Powertwin - The back wheels are splaying when the kids are in it,causing the brake to catch when moving. The bar holding the wheels in does seem quite lose, does anyone know if this is a common problem with this pram, is it easily fixed?
Many thanks
  • 2 more comments
  • 7dixons Oct 09, 2008
    Sorry, need to add, it makes a constant juddering noise aswell as you move along from the brakes and wheels catching I think.
  • aga77 Oct 24, 2008
    I have the same thing happening to my Powertwin. It started basically at the very beginning of using the stroller. The rear brake bar does not seem to lift high enough not to get caught in between those "teeth" on the wheels. I always make sure that I lift the bar as high as possible but it does not help.
    May be it is some failure in these strollers.
    I wish I knew how to deal with it cause it's really annoying.
  • tasha_1979 Nov 11, 2008
    i have exactly the same problem, have tried kicking banging, tilting, does anyone know where you can have prams repaired (cannot take back to shop as bought 2nd hand) would be greatful, live in northants.
  • Anonymous Jan 04, 2009
    I have the same problem, the back wheels are not vertically aligned anymore, but ar tilting inwards at the top.
  • 4 Answers
I had a similar problem and I had been told to go to a bike shop as they help you (you can get spare wheels from them too)... Cheaper than from online shops.. They can sort buckled wheels which is what my problem turned out to be!!!!
Posted on Jun 25, 2009
  • 297 Answers
To heavy load or worn out wheel bearings.
common on all kiddy carts.
http://www.janeusa.com/
Call or mail for distribitor.
Don't forget to rate me, thx
Posted on May 06, 2009
The front end jane powertwin snapped in half, need spare parts
you can get it fixed at buggypitstop. Just contact them on www.buggypitstop.co.uk they will help you out with this problem.
Dec 19, 2009 | Baby Gear
I have a jane powertwin pro and the rear bar that hangs above the clogs for the rear brake constantly rubs on the cogs making a grinding noise with or without kids in it. Please help
This sounds like either your brake bar is loose or has been bent out of shape. Look at the silver metal pins that click into the black cogs (on the inside of the back wheels), if these are not horizontal, then your brake bar has probably suffered some stress, causing the bar to bend and the pins to touch the cogs.
If the metal pins are totally horizontal, then your brake bar is just probably loose and needs removing and re-rivetting on tighter.
Either way, I would suggest that you contact (if in the UK) this link:
www.johnstonprams.co.uk
who will be able to assist with the repair. You can also take this back to the retailer and arrange a repair through them.
I hope this helps.
Sep 29, 2009 | Jane Powertwin - Silver Jogger Stroller
Jane powertwin splayed back wheels-rear brake plastic bracket
This sounds like some kind of excessive weight on the handle bar or a buggy board has been used, either that or too much pressure has been applied to the break bar. On the break bar, this should have a natural curve to it, if this looks wonky, then this is probably the reason. If this is the case, then the bar will have to be drilled off, straightened and re-rivetted back on.
I would suggest that you contact either your retailer for repairs advice, or www.johnstonprams,co.uk please note that this does sound like you will have to pay for it to be repaired.
I hope this helps.
Aug 15, 2009 | Jane Powertwin Azulon Stroller
Where can I buy a front brake disk for my Jane powertwin
try http://www.samueljohnston.co.uk/acatalog/Spare_Parts.html. If not try going to John Lewis and they will give you details of Jane's UK distributor who can supply spares.
Jul 28, 2009 | Jane Powertwin - Navy Jogger Stroller
Jane Powertwin Pro Buggy Problems
To lock the front wheel there is a small black button that can be twisted. It is very stiff on my buggy but if you fiddle with it while the wheel is straight it will lock it.
Jul 12, 2009 | Jane Powertwin - Navy Jogger Stroller
The front wheel of my Jane 360 wobbles, meaning I
I was able to get the contact details for the UK distributor for Jane from John Lewis. They were able to send me a whole new footplate.
Jul 08, 2009 | Jane Powertwin - Navy Jogger Stroller
Popped tire on Jane Powertwin
Yes, all you need is a 12" inner tube which you can get from most bike stores. It would normally fit a childs bicycle but it is the same size as the Jane rear wheels. If you take the wheel with you, you might even get them to fit it.
Apr 17, 2009 | Jane Powertwin - Silver Jogger Stroller
Jane powertwin
You should be able to download the instructions from www.jane.es.
If these are not of help let me know and I can 'talk' you through it.
Apr 05, 2008 | Jane Powertwin Azulon Stroller
Broken wheel
i went to strollermama.com/Jane-powertwin.htm. and it looks like they can help with part for your problem
Jan 22, 2008 | Jane Powertwin Azulon Stroller
Jane Powertwin Azulon Stroller Logo
559 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
