Question about Dell Inspiron 1200 14.1 XGA LCD Display-320-4222 (3204222) CD-ROM Drive
Dell Inspiron 1200 Charging Problem
Won't recharge when charge plugs in. Charger and battery are good. Charges very intermittently. Checked motherboard for cracks and bad solder joints. Changed jack. Still won't work. Charger is fine, battery is fine. Just won't charge.
Can I power the thing with voltage to both sides of the mother board?
  • Eaglo Oct 09, 2008
    Won't recharge when charge plugs in. Charges very intermittently. Checked motherboard for cracks and bad solder joints. Changed jack. Still won't work. Charger is fine, battery is fine. Just won't charge.
  • Anonymous Jan 13, 2009
    I just got a new battery for my dell inspiron 1200 to replace an old dead battery- when i put the new battery in- it worked for a bit and died on me- when i went to charge it, it did not- everything works fine with computer- its just not charging the battery when its plugged in- what should I do? Get a new battery again??
    Sergeant:
    Champion:
  • 318 Answers
Was the battery a Dell replacement? or was it a Chinese replacement battery?
Your charging circuit may have been damaged.
Posted on Jan 16, 2009
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Plugged in not charging
The charging circuits in the motherboard are not functioning or the new rechargeable battery is bad, this can be checked with a digital meter to determine if the proper voltage is present at the laptop terminals.
Jul 02, 2012 | Dell Inspiron 1525 Laptop
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
the problem is batteries wear out. You will most likely need to replace it
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
Sep 01, 2010 | Dell Inspiron 1525 Notebook
My Dell 1525 has had ongoing problems in that it wont charge. Runs fine with the cable attached but no charging. Tried charger from another Dell with same problem. When looking in bios comes up with...
Try the battery from the other Dell system. If it charges fine, then its a problem with the battery, go for a replacement. Else, try updating the BIOS once from http://ftp.us.dell.com/bios/1525_A17.EXE. If it still doesn't charge the battery, then you may have to go for a motherboard replacement. If the system is under warranty then call Dell Tech Support @ 1-800-624-9896.
Good Luck!
-Abhishek
Apr 05, 2010 | Dell POWER SUPPLY Power Supply
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
New battery not charging
It is normal for a battery to degrade after a year since its a consumable part. It's just like any ordinary rechargeable battery. We have 2 points of failure that might be causing the problem. First the battery itself. Second the Charge board that charges and detects the battery. Given that the NON-DELL battery is working on other dell Computer, it simply tells us that it is the charge board that needs to be replaced wich is integrated to the motherboard. If your warranty is still active, call dell and tell them that you've tried a Known good battery and its still not charging. However, you might also consider that dell computers are designed for dell batteries. the charge board might have problems charging the third party battery since its not configured to do so.
hope this helps.
Demmy
Dec 10, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
1,164 people viewed this question
Alun Cox
