Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Electrical Problem I have a 1998 ultra classic and when I start the bike the headlight high beam indicator stays on whether it's on high or low beam & the headlight doesn?t come on low beam. The spot lights will work when the switch is in the low beam position but when I switch to high beam the spots get real dim and the head light tries to come on but it's dim to. Another problem is the turn signals, when I turn them on they will not shut off automatically but other times they do work, intermittent.
  • gliderider20 Dec 06, 2008
    I have the same problem, were you able to solve this yourself?
Check ignition switch and wirring , may have a short. had similar problem on 84 ultra wirring at switch had shorted out on frame
Posted on Dec 05, 2008
  • vheaslet10 May 24, 2012
    I have 12 volts going to the head light , all other lights are working just low beams are weak and high beam don't work
Why does the headlight and high beam indicator not work?
The bulb for the indicator is burned out, change it and all will be OK!
May 06, 2014 | 2006 Honda VTX 1300 C
2004 harley ultra headlight goes out when you start the bike
Do you mean it dims or goes out and stays out while the bike is running or it blows a fuse OR?????????????
Apr 21, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
Headlights wont turn
sounds like the headlight switch is defective and needs replacing,but you need to check to make sure the rod that the switch pushes against if make the full travel and not short as this will not allow the switch to change from low beam to high beam.if the rod is travelling the full length then the switch is no good.you should also hear a click when moving the arm to go from low to high if not then the switch is bad.by holding the lever at a certain position to get the high beams to work this also indicates a switch problem.
Nov 04, 2013 | Cars & Trucks
Headlight low beam is dim but high beam is full force how can this be fixed
Check for corrosion at the low beam connection to the headlight. Yamaha electrical systems are notorious for having more wiring than is actually needed to make things work, so if it has separate grounds for both the high and low beams, check the low beam ground for corrosion or loose connection. Good luck!
Sep 22, 2012 | 2002 Yamaha V Star Classic
Keep blowing headlight and spot bulbs on 2003 Heritage Softail
A good start would be to check the VOLTAGE at the headlight. If at any time the voltage exceeds 14V (at all engine RPMs), replace the voltage regulator.
Jun 13, 2012 | 2003 Harley Davidson FLSTCI Heritage ...
My daytime running lights work, high beams will come on but switch wont stay on, have to hold it. Low beams do not work and daytime running light dash indicator stays on all the time. Is it a relay or...
if you have to hold the switch so the high beams stay on then that indicates a bad/worn switch,you could have 2 problems the day time running light relay may have a problem with it.i would first replace the headlight switch at the base of the steering colume as by the info you supply its not changing to the high beam side without holding the switch in position.
May 25, 2011 | 1998 Pontiac Sunfire
Garage door opener
Yes. This video is for a different bike, but the same thing will work on your bike too.
Jun 30, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
466 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
