Question about Sony CDP-CE375 5-Disc CD Changer
Setting up new CD laser
I have numerous single, twin and multidisc cd players that are traded in (I install PA systems) I can swap either the optical unit or the whole sleds quite easily, and all the units will work, but if I fit a new optical unit or a complete sled (ie KSM-213CCM) they don't work. I can't see anything obvious with the new parts that would prevent this, also assuming voltage to laser pot is pre-set at factory. Tried increasing one pot by a tiny turn but still not working. I have a Sony CDP-CE375 to fix and two Numark twin DJ cd players, all using KSS213C. On box with laser only it says 'Remove Antistatic lock before use, but when compared with original unit I can't seem to find a lock!!!
Sometimes cleaning lens works, but only for short time depending on the customers environment.
  • cablemanuk Oct 10, 2008
    Thanks so much for the advise, I knew it must be something that simple!! I used braid. Why do they that, is that a way to keep static from the lens pcb?
    Once again thanks for superb advise, my customers will benefit greatly from this!
    Scholar:
  • 92 Answers
Any new laser will not require any adjustment, most modern CD players do a self calibration on power up. There is a small dot of solder that must be removed somewhere on the circuit board. You'll see it's shaped like two half circles with a small gap between them which is bridged by solder. Remove this and you should be good to go! You should just be able to touch a soldering iron to it and drag it off. Or you can use a "solder ******" or de-soldering braid.
Posted on Oct 09, 2008
  • Inno Laur Oct 10, 2008
    I think it prevents static from destroying the IC that's mounted to the board, not too sure.
Bose multi CD changer will not play anymore
In most cases when the CD does not play it ispossible that the optical head is a suspect. Sometimes it might pick up ordinaryaudio CD but will not play other formats. This indicates that the optical headis weak and so there is no detection or scanning of the CD. If the optical is workingthe tracks will be read immediately but with no scanning the laser head can bedefective.The main motor will not work in some cases asunless the tracks are read the drive motor will not work with signal from theprocessor. Also in some cases the central motor base can shift and so thedistance to the disc can be more resulting in low detection. You can pull upthe spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it willnot be read and so will reject. Hence it is ideal to manually clean the laserhead eye using a cleaning swap /cotton bud with gentle pressure on the lenseye.
If there is no result then watch if the CD spins or tries to spin. If so theboard seems to work unless a test is taken on the main board but thepossibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of amalfunction of the main processor board
Jul 05, 2012 | Bose Wave music system Multi-CD Changer...
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
Why doesn't my DVD player read DVDs ?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Aug 22, 2011 | Panasonic Televison & Video
LG DVD PLAYER DP 171 First problem: don't read any dvd, but main motor work. I have changed de laser module, but main motor doesn't work. Before, the main motor work. How is possibile to...
Now since you have changed with a new one ( please make sure that the solder jumper was removed which is for static damage security in the new unit)
Jul 07, 2011 | LG DP-171 7 in. Portable DVD Player
The cd player says error and will not play any cd's
A lot of times, cd players will show error, so like all of us, is start putting in all kind of other cd's even music we don't care about, like buck owen's and the bosby twins. Been there done that. Sounds like you have done everything at your end. So, here is what you do and most likely it will solve the problem. At almost any radio shack, best buy store, or stereo shops, they all have little Cd cleaning kits, it goes in like a regular Cd but cleans it, pretty easy and simple to use. Some times its just like putting a couple drops on a blank Cd with some rubbing alcohol and letting it cycle through for a few minutes. I hope it helps, please let me know, so you can get back to rock'n and drive'n
Jun 13, 2011 | 2006 Hyundai Tucson
Skips when playing cd
In most cases when the CD does not play or is skipping it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Apr 15, 2011 | Audio Players & Recorders
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Cd player
"PEO" USUALLY means Player Error Optical,which means in most cases the
laser has malfunctioned.When this happens of course,no CD or disc will
play. You can try and clean it with a disk cleaner and if that doesn't work you are probably gonna hafta buy a new cd player. I have a link to a best buy private auction that lets you bid on things like cd players and what not. I bought one, a Pioneer DEH 2900 for 16 bucks!, Lemme know and I'll have it sent to you.
Jul 15, 2008 | 1997 Honda Accord
Sony CDP-CX455
did you have any luck with swapping the channels to determine if which is bad, cd or system?
regards
Graeme
Mar 28, 2008 | Sony CDP-CX210 200-Disc CD Changer
CD player
It may be power problem/Lens cleaning
Dec 09, 2007 | Audio Players & Recorders
Sony CDP-CE375 5-Disc CD Changer Logo
1,346 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
