Question about Toys
Coin pyramid puzzle
You have a pyramid of coins. 4 on the bottom row, 3 on the next row, 2 on top of that then 1. THey pyramid is pointing up. YOu need to move the pyramid to pointing down in 3 moves.
  • ditchdok Oct 12, 2008
    There is a triangle pointing up, change it to point down with only 3 moves
These are the coins
Solution:
On the second row move the coin on the right up.
On the third row move the one at the far right to take the place of the second row right.
On the third row take the one at the far right and put it at the top left.
Voila
Posted on May 30, 2009
I was hoping you had the answer
Posted on Oct 31, 2008
Clean the trap
AFFINITY COIN TRAP
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion piece. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
6. Reach inside the coin trap and clean what is inside of it out.
7. Put the unit back together following the same steps backwards
Jan 04, 2013 | Frigidaire Affinity ATF7000E Front Load...
My affinity dryer wont spin
Try to clean out the coin trap and drain lines first.
1. Unplug the unit.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 10, 2012 | Frigidaire Affinity ATF7000EG
Why washer leak from the bottom
You would need to try to clean out the coin trap in the bottom of the unit.
1. Unplug the unit.
Sep 09, 2012 | Frigidaire ATF6000ES Front Load Washer
Electrolux front loader drain problem
1. Unplug the unit.
Sep 06, 2012 | Electrolux Washing Machines
What does E 20 mean?
Error code E20 means that the coin trap/drain pump hose needs cleaned out. It can be done by the owner with a friend helping:
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.Or you can lay the unit on its back side.
3. Now that the unit is propped up look inside the hole on the bottom of the unit - on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
Here is to get you fixing the machine; thats your service manual: http://www.mediafire.com/download.php?0gy1jnemjdp
Hope helps.
Jul 28, 2011 | Frigidaire Affinity ATF7000E Front Load...
We want 10 rupees change in 10 coins but don't include 1 rupees coin and 50 pais coin fined out the answer
What coins are available? 5 rupee? 4 rupee? 2 rupee? 1/3 rupee? 1/4 rupee? 1/10 rupee?
10 times 1/10 rupee leaves you 9 rupees short.
8 times 1/4 rupee plus 2 times 4 rupees gives 10 coins and 10 rupees.
6 times 1/3 rupee plus 4 times 2 rupees gives 10 coins and 10 rupees.
Dec 14, 2010 | Computers & Internet
What is error coe e20? and how do you fix it?
hello mike means the coin trap is clogged. Here are the steps to fix the problem.
1. Unplug the unit.
2. Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
3. Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
regards
shaun
May 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Water won't drain, error message: E20
error code E20 means that the coin trap/drain pump hose needs cleaned out.It can be done by the owner with a friend helping.
1. Unplug the unit.
Of course, if your washer is setting on top a drawer/pedestal then you will need to take out the screws that connect the two and then you can lay the washer down on its back onto the pedestal
Jan 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Level 3 -a or one
Coin 1: After the checkpoint, there are pipes blowing bubbles upwards. The
second set of pipes is a red followed by two greens; enter the first
green pipe (the middle pipe of the set) and swim across the cavern to
get the coin.
Coin 2: About two thirds of the way through the level, the coin can be seen at
the top, between two bubble-blowing pipes. Swim up and get it, but
beware the purple fish that will swim after you.
Coin 3: About three quarters of the way through the level, there is a P switch.
Hit the switch and immediately swim right; the coin is easily grabbable
at this point.
Apr 11, 2009 | Nintendo New Super Mario Bros. for DS
Toys Logo
1,160 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
