Question about Sylvania LC260SS8 26 in. LCD Television
POWERING ON WHEN I TURN ON MY TV, THE GREEN POWER LIGHT BEGINS TO BLINK AT A STEADY PACE, TV COMES ON (BLUE SCREEN), NOTHING ON THE SCREEN. GREEN LIGHT BEGINS TO BLINK RAPIDLY AND TURNS ITS SELF OFF. THIS ALL HAPPENS IN A MINUTE.
  • mwoodend Oct 29, 2008
    I have the exact same problem with the 42 in. LCD from sylvania.
    It either a) turns on b) green light blinks slowly, then quicker, then shuts off c) won't turn on at all
  • Anonymous Mar 17, 2014
    power light is on,but the screen is black
  • 64 Answers
Good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Posted on Oct 09, 2008
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KDF-E42A10 42
I replaced the bulb recently on my tv and did not push the bulb all the way in. I had the same issue you are having now, and I was able to get it to work when I realized it had not been installed properly. Make sure you push the bulb in all the way then push down on it so it sets in nice and snug. Sounds like someone replaced the bulb and installed it wrong like I did the first time. Good luck.
Feb 17, 2009 | Sony KDF-E42A10 42 in. LCD Television
Pioneer SD-P5913 Projection TV
How many times does it blink, or is it a steady blinking?
Sep 01, 2008 | Televison & Video
Sylvania LC260SS8 26 in. LCD Television Logo
453 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
