Question about HP PSC 1110 All-In-One Thermal Printer
Cant print I will go weeks without problems then suddenly cannot print. Status is offline but for "copy 2" status is online. Either i need to know how to change 1st to online or get "copy 2" to print. i need help badly. thank you in advance...i'll be waiting!
  • 2,351 Answers
Hi talodyis,
Some how someone has created, (Copy2). (It shouldn't be there at all nor a Copy1).
Only an icon of the HP PCS 1110 series & HP PCS 1110 Fax.
Let's try the easy way to fix this first!
Left click the Start button once & slide up to & left click once on Printers and Faxes.
Printers and Faxes window will open. Find Copy2 & right click on it once, slide to & left click Delete. (Copy 2 should go away)!
You still have an listing of an HP 1110 here in Printers and Faxes window.
Find the HP 1110 series printer from the list, right click on it once & from within the pop-up window left click, Set as "Default Printer". That should do it. Play it safe & restart the system.
Posted on Oct 28, 2008
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
Jan 15, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Photosmart c6180 printer status offline
IF you have more than one printer set up on your system take all the others off except this one if you are able to without disrupting your home printing flow for others.
Another suggestion would be to download the newest drivers if you have not already; I found the site below with the drivers for this printer at:
Hope this helps.
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
Cant print . says something about offline.
go toand open printer settings click the printer icon in that menu it should say use printer online highlight and click.
Good Luck
Jan 30, 2009 | HP PSC 1210v All-In-One InkJet Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
My printer says it is offline and now it wont print
perform the steps below if the Operating System is XP
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Nov 28, 2007 | HP DeskJet 340 InkJet Printer
Printer light keeps blinking and status stays offline even it is READY
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP PSC 1110 All-In-One Thermal Printer Logo
102 people viewed this question
Ben Johnson
