Question about Bose (321GS) System
Bose 321 digital audio signal
I hooked up my bose 321 system with a hd digital cable box. I also connected the red and white audio cable plus a optical cable to receive the dolby digital 5.1 sound. The bose system reads the signal as sat/cab 2.0 . When I disconnect the hdmi cable to my tv. the signal then changes to dolby 5.1 with but with no vidio. The optical cable is connected to the cable box per the instructions with the bose system. I imagine its a matter of setting something different, but Im all out of guesses.
SOURCE: bose 321 cd/dvd tray stuck closed
can you post the disassembly page in with a larger view? This is too small to be useful
Posted on Jan 19, 2008
  • 14 Answers
SOURCE: bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Posted on Jan 26, 2008
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Surround sound
your tv might have aux out on the back, I would use that first.
IF NOT, then you will need to use the cable box.  Insert the red and white plugs at the other end of  this cable into the AUDIO IN TV or cable box connectors on the
media center.
Be sure to match red to red and white to white.
3. Use your TV remote control to turn the TV speakers
down to minimum volume.
This prevents the echo effect of audio playing
through both the TV speakers and your 3•2•1®
system speakers.
Apr 09, 2009 | Bose Cinemate Digital Home Theater System...
Hooking up bose 321 to my tv
I am about to go through the same process. I have a Bose 321, and am on the verge of getting a HDTV. From what I can figure, the Bose can play a dvd and input it to the HDTV via video and audio output plugs off the back of the Bose to the audio/video input jacks on the back of the new HDTV. I think individual cables will have to be run for each. They usually are red or white, sometimes green or blue. I am sure everyone has seen these in their life. The Bose 321 technology only had what was called an S-Video cable output for the best picture, which is how my current tv gets it's Bose signal, but now HDMI seems to have superceded S-Video. Therein lies an obstacle to be overcome.
Dec 14, 2008 | Bose 321GS Series II System
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
BOSE 321 GSX
1st thing I would try is to connect a different speaker to right output...if it works, that eliminates speaker problem. Then swap red and white audio input cables and hook them up backwards- connect red cable to white on both ends, and white to red...cable could be bad internally. Also try hooking another source to inputs, could be blown channel.
Jan 20, 2008 | Bose 3 2 1 GSX System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose (321GS) System Logo
78 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
