Question about Samsung Televison & Video
Ihave a ln 54051d 40 in. for 2years I have blue bars along with a shaky picture with outline litering on my close capture had comcast look at it not cable problem the blue bars are all along each side and lower left cornor collor picture is good reception is good best buy has no repaire men please help robertdrossi@msn.com 5616389143
  • 1,586 Answers
Sounds like the guns may be going out. See if you have a calibration feature on your main menu to calibrate the screen image, and try that. If not, it's possible that your projection guns are going bad. Mine behaved similarly to this (JVC i'Art TV) and that was the repair.
Posted on Oct 09, 2008
Picture comes on ok to my LN40C550 Samsung, then colored lines begin to appear through the middle of the screen, almost like a colored bar code
Sounds like a T'Con board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Samsung LN-S2651D 26 in. LCD Television
Ln key
Type expression and then enter. See captured image below
1d75e4a5-525c-4033-8091-ea9c563e3019.jpg See captured image below
Jun 23, 2013 | Texas Instruments TI-84 Plus Calculator
When taking pictures outside or from inside through a window, the picture comes out white with faint red outlines of some images. Inside the house and darker areas it takes pretty good pic's. What can be...
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
Jan 30, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Viewsonic sreen isn't displaying the picture
More likely to have bad caps, see example here: http://s807.photobucket.com/home/budm/allalbums
Common problems to ALL brands, they all failed after a couple of years.
Jan 17, 2010 | ViewSonic VX2235WM Monitor
I have no volume and the direction are not in english.tom tom xl330
I am enclosing a few screen captures to help you find your way.
Language
Tap the Change preference icon. It is the one with the blue wrench to the left of thae orange arrow on the top picture. Once you are in change preferences, use the right arrow to explore the options. Find the icon that is shown on the next picture (the Flags). Use the Up and down arrows that will show to the right of the list of languages to select the language you want.
Volume
In the following screen capture, the status bar (the blue bar) is horizontal.
To change the volume you tap the status bar near the middle and a volume slider control appears. Move slider to the right to increase volume.
Jan 03, 2010 | Tomtom ONE 3rd Edition GPS
My picture has been getting a blue area in the lower right hand corner of the screen and it is getting bigger farther along the bottom and the right side, also noticed a ring or outline of a circle when...
It is light engine that is going bad and causing blue haze/ clouds etc.
It is an expensive part, and I would recommend a new TV instead of its repair.
Thanks.
Sep 08, 2009 | Hitachi 50VF820 Projection TV
Lifecam VX-3000 cannot capture image, video, or sound.
READ THIS SITE>>http://www.microsoft.com/hardware/digitalcommunication/productdetails.aspx?pid=007.Everything you need is here.this is a solution.when you vote if this worked vote blue ty.RICHARDM69
Nov 27, 2008 | Microsoft LifeCam VX-3000 Web Camera
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Aug 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
My Samsung LN-83251D is not working properly. Instead projecting a picture, it just displays bars and lines. Is my LCD TV broken?
Jul 06, 2008 | Televison & Video
Blue shadows in pic.
glycol leak....bad stuff....conductive and corrosive. the blue tube might have to be replaced along with anthing that it has leaked on.. just depends on if which seals have failed
Mar 13, 2008 | RCA D52130 52" Rear Projection Television
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
149 people viewed this question
Jerry Greenberg
Jerry Greenberg
