Question about Westinghouse LCM-19v5 Monitor
Westinghouse bad caps answer
How do I find the article written by you (sillybit) on fixing the Westinghouse 19v5. My 20v5 had bad caps . . . .
Thanks
    Problem Solver:
  • 5 Answers
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
My Westinghouse LCM 19v5 will not powerup
Look for bad caps with bulging tops, similar to the 19" version as shown here:
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LCM-20V5/
Make sure to use correct type caps for switching power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
I have a westinghouse LCD. it randomly shuts off. i need a simple fix please, help!
It will not be easy fix since you will have to do in-depth troubleshooting to find out which board/s are bad first. So please read my guide and you will have some ideas what to look for, voltage checkinga and visual inspection in the power supply will be the first place to look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-27w7+
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Nov 12, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
I have a westinghouse 19 with a broken backlight
There is a chip in your monitor that is burnt out. To replace it would cost you about $150.00. To remove it is even harder as it is in the inside mount to your screen. If you are able to remove your front screen and put it on a board you can use your tester to find the chip. It would be cheaper to buy yourself another monitor. As the hours it will take to do this are intense. If you don't have the time to do this all in a day don't do it, as your memory will run into problems trying to accomplish this over a period of time. Try craigslist. Let me know if I can help with anything else. Thanks.
JimmyC
Sep 25, 2009 | Westinghouse LCM-19v1 Monitor
I think I also have a bad power board.
Could be a bad fuse in the powerboard,ore look for bad caps...
Jun 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor works for a fraction of a second
See article written by sillybit (me) for the Westinghouse 19v5. My 20v5 had bad caps in the power supply - it did the exact same thing as yours. $8 worth of parts from radioshack and an hour or two is all mine needed.
Aug 01, 2008 | Westinghouse LCM-19v5 Monitor
Westinghouse LCM-19v5 Monitor Logo
307 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
