Question about Epson Stylus Photo R300 InkJet Printer
Error messages The window says General Error or Paper Jam and I am positive there is no paper jam. It even sent a piece through when I turned the power off. I have messing with this thing for weeks trying to figure out why it won't work. This printer has really not been used much at all. It has new ink cartridges. I'm even thinking of buying a used one on ebay since I have all new ink. Thanks for listening. Jan
Hi Hope it's not too late, but try this. Hold down the power button, the low ink button and the stop button all at the same time for about 10 seconds. The printer will then switch itself off and reset. Hope it works, it did for me
Linda
Posted on Oct 28, 2008
    Problem Solver:
  • 4 Answers
Simply pull all the paper out, cancel all printing documents and then print the document (without putting the paper back) and if it comes up with the error that there is no paper than there is no jam and putting the paper back should be fine, however to be on the safe side try printing at first with one piece of paper for the first sheet then put a buch slowly adding to the pile per page utnil all the paper has been put back.
Hope theat Helps ^^
~VD
Posted on Oct 17, 2008
How do I get the paper jam error message to turn off after fixing jam on Dell C2660 printer
Turn the power off and let it sit for a few minutes. While it is off, open all the paper path access areas and check for any pieces of paper or buildups which may affect a sensor.
Close it back up and turn it on.
Here is a link to the manual, which has two good areas covering paper jam troubleshooting and resolution (around pg 300). http://www.manualslib.com/download/577729/Dell-C2660dn.html
Mar 03, 2015 | Dell Color Printer - C2660dn
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
I have a konica 2400 w magic color. error message paper jam when no paper jam
Hi Camru, I wondering if the jam light is on at power up before data is sent to your machine or if it occurs after a print job is sent to it?
If it is on constant ie before a print is sent to it, then we have a sensor or paper detect switch activated. If this is the case then it can be a piece of paper or a remaining fragment of paper holding down the switch or the switch arm itself is broken or its corresponding light sencing photocell is covered in toner/dust.
In Printers there are a number of these sensors in the paper path, generally we have one that detects paper at cassette and bypass position, another at registration roller another at fuser exit, the machine monitiors these switchs for activation to tell if a jam is present. These switchs are tiny plastic arms that get pushed down when paper passes them which in turn blocks the photocell sencing light. One normally finds fragments of paper sticking the arm down, or the arm broken, most of the time the printer also tells us jam position so we know which switch it is seeing a jam condition at. Check the switch operation by looking for them, and ensuring the arm is moving freely.
The other possibility is the machine with no data present shows no error but a error occurs when a print job is sent to it. If this is the case it is caused usally by incorrect paper size settings in printer paper size menu or the printer drivers paper size settings on installed driver in printers under control panel of computer, It can also be caused if the paper is feeding multi sheets from cassete due to dirty rubber rollers in printer itself or not picking paper from tray at all as the feed roller is slipping on paper in tray due to losing its grippyness.
I clean feed rollers with water, just slightly damp rag and rub the rubber surface of the feed roller, sometimes they are so worn they need replacing, I will post a pic for you and also here is the service manual of a machine pretty much the same as yours.
This is another uses post on how he fixed his, please note this will be the same as yours only if jam only occurs after data is sent to your machine.
Cheers
Steve
Feb 03, 2012 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Paper jam went try to sent a fax
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Mar 30, 2008 | Lexmark X4270 All-in-One Multifunction...
Epson Stylus Photo R300 InkJet Printer Logo
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
