Question about Zenith Z32X31D 32" TV
Power in, but won't power up
I replaced CX3116 (it exploded) and QX3208, but the set still won't power up.
  • mission30 Mar 25, 2009
    I have burnt out rx3407 and rx3408, and I intend to replace them should I also replace str53041, cx3413, cx3416, rx3404, and qx3401?
Voltage regulator str53041, cx3413, cx3416, rx3404 (use 1/2 watt), and qx3401. Standard zenith fix.
Posted on Nov 28, 2008
    Champion:
  • 252 Answers
Check the diode connected to that parts most specially zener
Posted on Oct 10, 2008
The system does not power on. When the power supply was opened up, the 50 V capacitor exploded. When replaced, it got very hot and eventually exploded again.
Replace the caps and this time disconnect power supply rails that go to the amp module, then check positive rail for +30V and -30V, if they are present then your power amp ic's that if i remember correct are TDA7293 are blown, or at least one of them, let me know your results.
Aug 10, 2013 | Peavey Escort 3000 300 Watt Portable PA...
Replace power cord
Definately replace power cord. I work with these microwaves all the time and if you don't it will cause a chain reaction and the fuses will explode into tiny sparks. This is coming from an expert
Jul 25, 2013 | GE Microwave Ovens
Lg power supply
Do an internet search for lg power supply for LG37H30 replace the entire power supply! (because the damage may have caused other bad coponents do to that one ic exploding avoid a headache replace the entire power supply and start watching TV again.
Jan 21, 2013 | LG 37LH30 37 in. LCD HDTV
I have a jvc lt-32a220 flat screen and won't power
Power supply or microprocessor in the set---have you tried to unplug set and or box if used from power for a while and then power back?
Do I understand it is a new set?
Dec 09, 2012 | Televison & Video
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I heard a loud pop while comp was on -it shut down. Now blue power light wont come on --something with the power supply. If it is fried is it easy to replace? I have HP p6774y
The pop was probably a capacitor exploding and yes they are easy to replace. All of the power connectors are keyed so they only fit one way.
Here is a good guide with pictures on the whole process. Your computer won't deviate much from this. http://www.hardwaresecrets.com/article/362
Any power supply should be fine, you can pick one of from a best buy. 300Watts+ should be more than adequate.
Or pick one up cheaper online I prefer newegg.com
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%204093&IsNodeId=1&name=%2410%20-%20%2425
Here you can pick one up for as little as $12
Aug 04, 2011 | Computers & Internet
My computer was knocked forward it went bang and then smelt of burning - I have been told that it might be the internal powe pack can you help?
If your desktop computer went bang from the back of the computer and the burnt smell comes from the fan grill of the power supply then the switch mode power supply definitely failed. The bang and burning smell was probably one or more of the capacitors that has exploded inside the power supply.
You can replace the switch mode power supply, make sure you purchase one that has the same total wattage or higher wattage.
There is a chance that when the power supply failed it may have caused a voltage spike that could have damaged some other components. You won't know until you replace the faulty power supply.
May 19, 2011 | Computers & Internet
Loud bang from system.Unit starts immediately power is supplied.Power switch does nothing.H/Drive and players run.No video ( card OK ) checked with another card. Can the problem be motherboard?
The load bang is most like an exploding capacitor in the switch mode power supply, especially if there is a burnt electrical smell from the power supply.
I suggest you borrow a switch mode power supply, remove the old power supply and install the replacement power supply. make sure it has the same or larger wattage unit.
If the computer still does not boot up then the exploding power supply has damaged the motherboard, and you need to replace then motherboard too. This may not be a cost effective solution.
This is an opportunity to get a new and better computer.
May 16, 2011 | Computers & Internet
My 37'' LCD TV just made a crack sound then no sound or picture but the power light is on, any ideas? oh and a burning smell
I would guess that would be a Philips TV? Most likely a capacitor in the power supply has failed, and that pop was the capacitor exploding. For most sets a new power supply board is around $200+labor, although anyone who can do simple electronics repair could replace a failed cap for less, as long as that is the only problem.
Oct 20, 2009 | Televison & Video
Televison & Video Logo
156 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
