Home | Toshiba | 43H71 43 in. Rear Projection Television | 43h71 flashing power lig...
Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
43h71 flashing power light
By lucked on Oct 09, 2008
I know its been posted already but befor i go and spend the time and money on convergance chips can any one tell me a sure fire wayof telling if thats whats wrong for sure?
Comments:
Nov 04, 2008
- Is there anything elese that can cause the red blinking light problom a bad horz output maybe?
Best Solution
posted on Oct 20, 2008
Helpful)
tvrepairguy
Rank: Wiz  Toshiba Expert
Rating: 82%, 200 votes
Remove ic's and see if it fires up..
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Answer
Good sound but picture goes after a short time, half hour to about one hour. But now there is no... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1447
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
