Question about Compaq Armada E500 Notebook
COMPAQ ARMADA E500 WON'T TURN ON!
I can turn it on, but all I get are three green lights (shift,capitals,numlock).
It doesn't even get to a bios check, hard drive doesn't kick in, black screen, nothing.
So far I've changed motherboard & cpu.
Please any suggestions before I throw it out the window?!
Cheers
  • 1 more comment
  • theotherhs Oct 09, 2008
    Hi, Thanks.
    And no, no recovery disk, don't know if that would help anyway as nothing powers up at all, disc drive included so couldn't get a disk to run anyway!
  • capuccino7 Oct 21, 2008
    Exactly the same problem for me... But I dont want to through it out yet!! I'll try to boot it from a recovery disk, but I have the feeling it wont work... as Theotherhs said nothing seems to work.. only the fan and 3 green lights. Not even the Compaq splash screen appeared...
    Thanks for any suggestion!!
  • dagamer5 Oct 29, 2008
    It happened to me too. I think there's a bad connection somewhere inside that's stopping it from turning on except for the three lights. I looked but didn't find anything. The Floppy disk and CD Rom drives dont start so a recovery disk wont help. It could be something to do with the bios.
It happened to me and I went on the HP site and found how to fix it. Under the keyboard you can find the ram. If you take out the battery and disconnect it from the mains, then take the ram out and put it back in again, it can sometimes solve the problem. If not then there's something wrong with something else inside it.
Posted on Oct 29, 2008
    Master:
  • 538 Answers
Open the window first..right....he..he..do you have a recovery disk handy
Posted on Oct 09, 2008
Changing the BIOS for NumLock to be ON at reboot
some bios settings have this setting some dont just go to your bios settings and look for numlock boot and enable it
Mar 24, 2014 | Dell Inspiron 15 3521 15.6" Laptop...
My Optavision 9500 HD light will not come on when power up, it is not even a year old and doesn't get used often. So what does anyone suggest?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 25, 2012 | Computers & Internet
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Hi, I have an Acer TravelMate 5520, it will not boot up on the screen. The green power light on the on/off switch,the green light indicated by a lightbulb shape and the green light at the top which is...
Sorry to hear you're having trouble with your notebook.
The book indicator you referenced is the hard drive activity light. When you see this flicker it indicates the hard drive is being accessed.
With the notebook booted up, press Fn+F11 a few times to enable and disable numlock. If the numlock light(lock with the number '1' on it, next to the hard drive indicator) turns on and off then the problem may be only related to your monitor and not a failed hard drive, video adapter, or something like that. Believe it or not this could be a good thing.
With the computer booted up, press Fn+F5 and wait a couple seconds. This will toggle the display modes. Press Fn+F5 a couple more times to cycle through all the modes.
Also try pressing Fn+F6. This keystroke blanks out the display to save battery.
Do you EVER see anything on the screen while the notebook is booting up? You should see the Acer splash screen and maybe some information about entering the BIOS setup.
If you have an external monitor and a VGA cable(or DVI or S-video) you can connect the external monitor to your notebook then turn the notebook on. You may have to do the Fn+F5 keystroke after connecting the monitor to select the correct display mode. This will help us determine if the problem is the notebook monitor or not.
Here is a link to the manual if you need it:
http://global-download.acer.com/GDFiles/Document/User%20Manual/TM_5520_5220_ENG-OLM-0307.zip?acerid=633645712974910948&Step1=NOTEBOOK&Step2=TRAVELMATE&Step3=TRAVELMATE%205520&OS=ALL&LC=en&BC=ACER&SC=PA_7
Apr 19, 2011 | Acer TravelMate 5520 Notebook
Hi, How I shall get to know whether Keyboard's capslock numlock or scrolllock hey is on or off on Logitech Cordless MK250??? I am getting big trouble in entering different capital or small character's...
if the corresponding Numlock, Capslock, Scroll lock light are ON, then it says that the corresponding functions are activated...
For example if the Numlock light is ON, then you will be able to use your number pad...
if caps lock light is ON, then you will be able to use the Capital letters...
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
How to enter in the bios
Press F10 just after powering the PC, to access BIOS of your Compaq Armada E500 Notebook.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | Compaq Armada E500 Notebook
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
700 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
