Question about Sony VAIO FR130 Notebook
Booting in sony laptop
New keyboard fitted now all i get is a vaio screen no post
    Scholar:
  • 69 Answers
If you mean POST as in Power On System Test, then you can probably enable it in the BIOS.
Posted on Oct 09, 2008
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Sony vaio notebook won't switch on
Can you see any display from the screen? if its a new hard drive, with no Operating System the it show anything at all, try to insert a boot cd and boot from the cd
Oct 22, 2012 | Computers & Internet
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
I want to recover my sony vaio laptop with windows 7 OS, i want to get it back to original state to delete all personal installed programs. pls help
hope this helps
Sep 29, 2012 | Sony Refurbished White 14" Vaio...
Cant fx b4tt0n 5nt0 n40ber
Then replace the Keyboard.
http://www.sparepartswarehouse.com/Sony,Vaio,VGN-AR150G,Laptop,Keyboards.aspx
http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
In the above link where it states in bold letters -
Service manuals for Sony VAIO laptops and notebooks,
,left-click on - Get it here - to the right of VGN-AR.
This Service Manual is in PDF file format. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (VGN-AR), it may take up to 30 seconds, before the first page comes up.
Not your laptop, but perhaps this will give more guidance, in removing and replacing the Keyboard,
1) http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
2) http://www.insidemylaptop.com/disassemble-asus-n53s-laptop-fix-dc-power-jack/
Just follow the steps up to removing the Keyboard. These are listed just to give you more info on replacing a Keyboard, not disassembling the entire laptop.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ WOW, that Keyboard is expensive! Suggest you look around for a better deal. I just posted that example to give you info. Average price SHOULD be no more than $40 to $50. Ebay? ]
May 06, 2012 | Sony VAIO VGN-AR150G Notebook
I have a Sony Vaio VGN-FS840/W and the keyboard will not work until windows boots, but windows is corrupted. I cannot boot from disk to re-install it without the keyboard working. I want to reset the bios...
try using an external keyboard, reboot the computer then pre f10 key repeatedly for 5-7secs to boot to vaio recovery center.. select restore c: drive to format the harddrive to the factory defaults
Feb 27, 2010 | Sony VAIO VGN-FS840/W Notebook
Sony vaio laptop - some keys on keyboard does not work
you can use keyboard in the windows to replace keys dont work in your keyboard
go start-> program->accesoires->accesbility-> on screen keyboard.
or you have condition take to prepaire for change new keyboard
Jan 19, 2010 | Sony VAIO VGN-FJ270/B Notebook
Sony Vaio wont boot
Hm, maybe your bios battery is dead. Try to buy a new one, and boot than boot it. A bios battery is usually under the keyboard.
Mar 26, 2009 | Sony VAIO VGN-FS715 Notebook
Sony VAIO PCV-W700G Desktop PC
I would fold the inbuilt keyboard back and use an external keyboard.
Jan 11, 2008 | Sony VAIO PCV-W20 PC Desktop
Looking for screen and keyboard
eBay is the best place for this type of thing. It's way cheaper than any laptop depot I've come across. Here's one for your keyboard: http://cgi.ebay.com/Sony-Vaio-Laptop-Keyboard-VGN-T140P-HMB991-D01-NR_W0QQitemZ320137022753QQihZ011QQcategoryZ140084QQssPageNameZWDVWQQrdZ1QQcmdZViewItem As far as the screen is concerned; the way to get the best deal is to search by model number of the screen and not just laptop. The same screen can be used in several different laptops. Take your screen out and look on the back of it. There will be a model number there. Enter that model number into ebay's search, making sure you check product description to be included in the search query. Any screen matching that model number will fit your laptop just perfectly and it will save you a bundle.
Jul 16, 2007 | Sony VAIO T140P/L (VGNT140P) PC Notebook
Sony VAIO FR130 Notebook Logo
66 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
