I have a 29 inch Nikai Tv which was giving a problem of the 2 ends of the screen merging togather into a horizontal line in the centre....before i used to switch off the tv and start it again... but today it continued for sometime and after 5 mins it started giving a burnt smell...please help?
  • 64 Answers
Good day,
the burnt smell means that there are some loose connection inside your unit. have it checked immediately by a competent technician. you can also use your warranty card if it is still valid
Posted on Oct 09, 2008
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Circuit diagram 29 inch sony wega tv
Absence of 'Blue' is the fault. Check all the solder terminals to its video output card. This card can be located at the base of the CRT itself, will directly plugged on to its back. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 05, 2014 | Televison & Video
Samsung 29 inch crt tv picture problem a thin line appear in centre give me solution
These kind of problems are usually occurs due to vertical output section circuit faults. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 07, 2013 | Televison & Video
Hi, my samsung 29 inches got some horizontal line at a above of the screen. The line came out with 3 different colours. Can u show me how to remove it?
Smoothing capacitors to the vertical output section voltage should be checked. Replace them. Check this site for more details.
Jan 29, 2013 | Samsung CW29M64NS 29" TV
Pink/Blue horizontal line on TV
Considering it is a 32 inch set and costs now under 300 dollars it may or may not be worth fixing.
To give an educated guess: either whatever it uses for an inverter board may be bad or damaged OR even the main board that processes all signal into or out to the screen may have either a bad connection(unlikely but possible) or be causing this.
A fatal issue could be something wrong in the screen unit (panel) itself.
I gather set is not under any warranty at this time.
Apr 05, 2012 | Televison & Video
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
Screen goes to horizontal line
Maybe the vertical IC got some cracked solder joints and the reparation worth it
Apr 24, 2009 | Televison & Video
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
