Question about HP Officejet 7310 All-In-One Printer
Carriage error msg
I keep getting a carriage jam error message
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
The cd player on my 2005 vw golf keeps spitting out cds immediatly and a message 'cd error' appears. this error msg with an error tone happens 4/5 times after starting the ignition - is there a simple way...
It sounds like something is jammed in the carriage or the carriage assembly is bent slightly. You will need to remove it and see if it can be straightened, if not, then replaced.
Mar 15, 2011 | Car Audio & Video
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Carriage jam
cannot print, msg shows Error carriage jam, Open door, clear carriage jam, and then press o.k. to continue.
paper has been cleared , opened door and even took off back compartment
Dec 22, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Carriage jam message
I had this same problem and spend hours working on it. Took the side panels apart to get a better look. Nothing anyone said fixed the issue. Not even the link everyone keeps posting to HP's carriage jam fix. Was out of solutions and about to give up and order a new printer. There was one last thing I had to try that I didn't think was going to work, but I had a theory. Right after I tested this solution it started working again. This worked for me, but anyone who has tried every and have not got their printer to work can try it.
My Solution: Open the front covers and look inside. Just above the metal rail that the carriage travels on there is a thin plastic strip about 1/4 in. width and should have a glossy shine to it. I believe this is some kind of positioner. It runs through the carriage and gives it some kind of position. After years of use, it'll become dirty with ink. I used some tissue and alcohol and wiped the strip clean. It worked perfectly fine right after. Below is a picture of the strip I underlined with a yellow line.
Aug 27, 2008 | HP Photosmart C4180 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Seeker5211
Seeker5211
