On off button broken on techwood plasma tv - Televison & Video
  • 64 Answers
Good day.
check if your unit still have its warranty, if so, ask some assistance from your seller.
however if there is no warranty anymore, you can ask for assistance from techwood and have it checked. they might repair or replace the broken switch.
have them also check other non-obvious problems like possible loose connection of some wirings, etc.
Posted on Oct 09, 2008
I have an oldish Techwood 42" Plasma TV, my
Hi A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage. Hope this helps
Aug 09, 2011 | Televison & Video
Techwood 42" plasma screen television
Do not turn this television on! Any electronic that smokes is NOT GOOD! The smoke and accompanying smell is from plastic and solder that is being melted by a short on one of the TVs logic boards. Call a local TV repair man this is not an issue you could fix yourself and will most likely be better off buying a new television. Stay away from off brands like these, spend the few extra bucks on a name brand like Sony, Toshiba, LG, or Samsung and you won't encounter these types of issues.
Feb 15, 2011 | Samsung SPN4235 42 in. Plasma HDTV
We have power and sound but no picture , i have
If an authorized service repair center will sell you one. However looking at the reviews you may just want to replace the tv since even service centers have issues repairing the tv.
May 07, 2010 | Televison & Video
Techwood plasma twp 4210 broke
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 07, 2009 | Televison & Video
Techwood TWP4210 Plasma tv
a resistor has developed a dry joint or failed on the data connectors of the plasma panel,there are eight at the top of the plasma. An easy fix if you know what youa are doing,
Aug 24, 2008 | Televison & Video
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Ted scaning elektronik tv service
I have a TWP4205[samsung display s42sd-yd05] end VMB 1110 tuner box for TWP4210[LG panel]Hou switched in service mode,for geometry settings...please!
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
42 inch techwood plasma no picture
the most common cause for this is the capacitor (1uf 630vdc)located at c19 on the main power board.the cost for this component is around 90p
Dec 17, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Plasma tv techwood 4210
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
Oct 11, 2007 | Televison & Video
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
