Question about Panasonic NN-T990SA Microwave Oven
Panasonic inverter microwave NNT583SF
The problem with my microwave is that it turns off at 37 seconds every time. WHY?
  • IAmMisterWan Oct 16, 2008
    I have the same problem.
No prende
Posted on Nov 10, 2008
Panasonic Microwave will not work pass 20 seconds
Your Unit has an inverter, when the unit stops running after 10-20 seconds it is having a problem with either the Magnetron or the inverter. Sometimes both. There is not an easy way to test the inverter, the mag can be tested for shortage to ground with an ohm meter and between the terminals to check the filament for continuity. But if both are bad it is cheaper to buy a new unit.
Oct 26, 2017 | Panasonic Microwave Ovens
The settings on my microwave appear fine. Then I set the time for let's say 50 seconds and it turns off in 5 - 9 seconds. Then what you see is the correct time --- no other message.
If this is an inverter oven, it could mean that there is a problem on the inverter board. Testing these boards is fairly simple. You just need to find a service manual for that model.
Jul 18, 2016 | Panasonic Genius Prestige Inverter...
Mi panasonic prestige inverter microwave will not
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jul 18, 2010 | Panasonic NN-P295SF Microwave Oven
Microwave runs for 3 seconds and stops
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 31, 2010 | Panasonic Microwave Ovens
Microwave shutts off after 2 seconds/
If so, see
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 22, 2010 | Panasonic NN-S592 Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Panasonic microwave shuts off
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Dec 25, 2008 | Microwave Ovens
My microwave is a 32ltr 1200w NNT583SF Inverter. it is 4 yrs old. No matter how long i set the timer for it will only work for 23 seconds, then it just switches off??
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 05, 2008 | Panasonic Microwave Ovens
Panasonic NN-T990SA Microwave Oven Logo
113 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
