Question about Mitsubishi DD-4000 DVD Player
Hot to operate Spindle Motor with Mitsubishi Driver IC
Many computer CD/DVD ROMs contain a brushless DC motor and a Driver Chip, which controls the speed of motor, stop/start functions and other operations like operating sliding motor and torque controls etc. Is it possible to use that IC (M63016FP or M63022 FP) to operate that motor for my RC Plane? I downloaded datasheets for these ICs and studied although i dont know which pins do i need to run that motor continuesly.
SOURCE: Remote Control Programming
Go online and search for the owners manual for your TV. It has the common codes for receivers, DVD players, etc. listed in the back with the instructions on how to program the remote.
Posted on May 10, 2008
  • 87 Answers
SOURCE: 2004 Mitsubishi Diamante heat and Air blower motor.
OK... First thing it may be a (relay switch) they are cheep and installed in sec. Ok now if you dont know what one looks like then go buy one ol' rilley or pep boys or auto zone are somthing . while your there buying the relay talk to these people most of the time they are good at supporting people . So you may ask "hey can you help me find where this part is located" . Ask about the fuse to, once you get someone out there to help you . One thing I know for sure is you did look in the correct spots for these fuses but let me tell you worst case. Would be your heater switch is out. They are expensive and are only found at the dealer. I would recommend looking on e-bay if this problem comes to this. oohh if you cant figer out how to put one of these in then find a friend that is rely good at installing car stereo's Im sure you will win this problem.
Posted on Oct 07, 2008
  • 19 Answers
SOURCE: 380 ES Mitsubishi 2006 model door window control
It possably isnt the switch it maybe the motor itself if you open the door panel and disconect the moter run 2 wires to the main battery becarefull because when you do this the motor may or may not work if the window goes up or down when you do this then your moter is good if not replace motor otherwise switch your wires from one switch to anouther that you know is good and try to see if it works then your switch may be bad.. do to the drivers window being used the most the switch or motor will go bad sooner then the others
Posted on Jan 25, 2009
  • 333 Answers
SOURCE: mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
Posted on Sep 10, 2009
SOURCE: Mitsubishi Lancer dashboard instruments
Posted on Oct 06, 2009
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
I have a cyberhome 300 dvd it is in a sleep mode and I can not get it to turn back on . can you help me with this
There is a possibility of spindle motor problem. If the spindle motors is short or open then this model dvd players will not turn on from the standby mode. Just replace the spindle motor. And the check. Spindle motor is one in which the cd rotates.Have added the picture of spindle motor for your reference.
ajin_g_56.gif ok
Jun 13, 2011 | Cyberhome CH-DVD 300 DVD Player
The light on the dvd player won't turn green any more.I can't get it to play any more. If I did get it to play it would say bad disc the light is now yellow not red are green any more.
You dvd have problem with its spindle motor. Spindle motor is one on which the CD rotates. If the winding of the spindle motor become short this problem can occur. you can see the spindle motor in the center of the mechanism. spindle motor will not cost a lot. Just replace the spindle motor your problem will solved.
May 06, 2011 | Cyberhome CH-DVD 300 DVD Player
first of all check the spindle motor of ur dvd mechanism. if its winding or the brush short this problem can occur. when u insert a CD it rotates in a slow rpm, but DVD needs a high rpm. if the motor is short it will not rotate in high rpm, and will not read the dvd. normally there will be two types of motor uses as spindle motor. one is dc motor with two wire and the next one is servo motor with five or more connection.
the above mentioned problem will occur only in dc motor with two wire.
Also one another problem is the laser pick up unit. first check the motor, if it has no problem the go fo the laser pick up unit.
Jan 09, 2011 | Samsung HT-SK5 System
My pro-ject turntable is playing very very slowly.....I have changed the belt but no it likely to be a motor problem?
I'm unfamiliar with Pro-Ject turntables, but the following genral advice will still apply:-
With the drivebelt disconnected, does the platter rotate freely with little resistance?
If not then the problem is the spindle bearing (may just need cleaning and re-lubricating with light oil). Some turntables allow you to remove the platter and re-lube the spindle, others have a sealed-for-life bearing where the only option is to replace the bearing. If you have the latter type then take the bearing to a specialist bearing supplier as they'll provide an equivalent replacement for far less than an official manufacturer spare. It will likely be exactly the same part without the branded packaging anyway.
If the platter rotates freely and becomes very much more difficult with the drivebelt attached then you have a motor problem. Try a tiny drop of light oil at each of the spindle bearings: if this fixes it then the motor bearings may just have dried out or may be on their way out. If not then look to the motor brushes and either the motor commutator (if the DC motor has an AC supply) or slip rings (if the DC motor has a DC supply). These items wear over time and lubricating them can make things worse as the lube traps dust and bits of debris to become a conductive grinding paste. If you have a commutator then clean it thoroughly with a Q-tip (UK=cotton bud) moistened with a little white spirit or lighter fuel, and then use a cocktail stick to clean out any muck lodged in the gaps in the commutator. The motor brushes which contact the commutator/slip rings are usually made of graphite and on some motor designs they can be removed, inspected and if need be replaced, but on many small motors worn rings/brushes mean that the motor must be replaced as a complete unit.
If the motor used is an ultra-modern brushless design, then there will be no rings or brushes to cause faults but there will be a motor controller circuit which can go wrong. If so the controller needs either to be replaced or to be tested and repaired by an electronics technician. Note that brushless motors can still suffer with spindle bearing issues though.
I hope that my posting has been of some assistance and ask in return only that you take a moment to rate my answer.
Jan 24, 2010 | Maytag MMC5000 Microwave Oven
I am getting an H07 code
If memory serves me well, code H07 means that spindle motor has to be replaced. It is ease enough to test, remove top cover from the unit, load DVD disk, when disk is loaded try to give it clockwise push. If unit starts and works - spindle motor is the problem, if it will not start then spindle motor plus driver IC has to be replaced.
Nov 14, 2009 | Panasonic DVD-RV32 DVD Player
Panasonic RV32 DVD player has an H07 error
This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry.
u may try new spindle motor
Nov 12, 2008 | Televison & Video
Compo drive doesnt read
sir you need to replace your cd drive , it is physical problem of cd rom drive replacement/repair is only solution , out of with repair will be costly and repalcement best solution
Nov 12, 2007 | Compaq Presario M2000 Notebook
Mitsubishi DD-4000 DVD Player Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
