Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
File size is too long and is taking ages to send
PDF file 18 pages long is 22.1MB - can I reduce this?
Janice
    Problem Solver:
  • 15 Answers
Yes you can reduce it by selecting the resolution. basically you
1. select the dpi as 200*200. because it will give better resolution. No need for going to 600 *600 for text document.
2. you try to crop out (select the particular area of the image).
you try these. If it is not solved you can mail me at ramanathanr@integramicro.com.
Posted on Nov 11, 2008
How to solve the problem of undesired changing size after printing only in PDF files?
You should see the PDF as a picture. Nothing can be changed (unless you have permission)
Most of the time when starting the print job, the menu gives you some options to educe the size of the page or print to fit the page in the printer.
I hope this helps?
Jul 18, 2014 | HP Color LaserJet Pro 200 M251nw
Tip
Reduce the file size of a PDF file
Sometimes when we scan a document and the output file is PDF the file size is too big which is very difficult to send as an email attachment. This also happens when you convert word documents into PDF format.
This guide assumes that Adobe Acrobat Professional or Standard is already installed on your computer for PDF conversion.
On your current PDF File click on File then select Print
On the Print window select Adobe PDF as the Printer Name then click on the Properties Tab
On the PDF Document Properties Window under Default Settings drop down, select Smallest File Size.
Click on OK on all open windows. This will start the conversion process. When it's finished this will prompt you to save the file. It is advisable to save the file in a different file name rather than replacing the original copy.
After the conversion you may compare the file size of the original file and the reduced PDF file. The reduced file can now be sent on email attachments easily.
on Apr 10, 2010 | Computers & Internet
Lexmark 7100 scan to .pdf makes file 23 times bigger than usual
> it should be 2-300K
Only if you use Adobe Acrobat (full version) to create the PDF.
All the "text" in the PDF will still be encoded as "scalable text fonts",
rather than as bitmaps.
Anything you "scan" will just be zero and one values,
and the size of the file will be proportional to the amount of "black" (and/or colour) in the scanned image.
Nov 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I scanned a document, but when I go to attach the file, it stays in attaching files forever??
Greg, Do you mean that when you want to send it by email it keeps attaching the file forever? If yes then check the size of the scanned document. What happens is that the moment you attach a document to an email Windows start sending it to the email server and that takes time as uploading is slower than downloading. And if the file a large one as scanned documents can be, then it will take that much longer. Try a smaller document first. Size wise small document. If that works fine then you can try larger documents. yes it may be time consuming but there is no price for mental satisfaction. To reduce the size of the scanned document, reduce the pixels in settings of the scanner. or reduce the page size. You will find the document reduced many times over.
Nov 19, 2009 | Gateway Audio Players & Recorders
I HAVE A LEXMARK X9350 AND WHEN I SCAN ITEMS, THE FILE SIZE IS HUGE. EG 1 PAGE = 3MB. HOW CAN I REDUCE THE SIZE OF THE FILE
See the manual for X9350 on page 119.
The software application must be used for saving files to a specific format that you can select from the menu on the computer.
Standard scans are often saved as bitmap with the extension .bmp .
Select another file format like jpeg with the extension .jpg or .jpeg, when you want to view the scans in photoview afterwards.
Another option is to save the file in a format that can be read with Adobe Reader, selecting .pdf format.
A last option is to reduce your file size, changing the scan settings:
( I wouldn't advise; this can result in unclear copies ):
Advanced scan settings can be changed on the computer as well:
See reducing e.g. "scan resolution" and "color depth" on page 120.
Use the link support for Lexmark 9300 series for more help.
Sep 22, 2009 | Lexmark Office Equipment & Supplies
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
Apr 01, 2009 | Broderbund PrintMaster Platinum Version 18
Very slow PDF and large files printing
Change to print as an image.
Go to print then click on advance and select image.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
74 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
