No sound on my Samsung Syncmaster 920lm Monitor
I have connected my computer up but have no sound. I have tried to install everything on the computer but it cannot find the attached speakers.
This seems to be easy.
1) Your monitor will need to be connected to the sound output using a separate cable, unless it uses HDMI cabling.
2) If that doesn't help, check the sound output using headphones or a different speaker system.
Check it out and post your response here.
Posted on Oct 09, 2008
Samsung syncmaster 920lm wont stop going off and on
For this case, you need to open lcd case and try to find power inverter board. That cause by cold soldering joint and you need to check and resolder all them.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Jun 30, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
The top part (about one third) of my SyncMaster 920LM screen is brighter than the rest and seems to retain simultaneously the new and the previous picture for 2 to 3 seconds before it gradually fades out...
This is usually do to a section of your controller chips dying. This is not fixable by the end user, the only thing I could say to try is to try different resolutions to see if you can reduce the issue.
Mar 15, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
When I open the Monitor (samsung syncmaster 710n) everything is OK! As I soon as I connect the vga cable from my pc the monitor turns on stanb by mode and does not react to any buttons!
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Feb 10, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
When i turn onmt Samsung SyncMaster 920LM 19 inch LCD Monitor it blinks on the left upper corner for a few moments
WQhen you get strange problem like this, first place to look will be the caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Jun 14, 2010 | Samsung SyncMaster 920LM 19" LCD Monitor
Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
Follow the directions and good luck!
May 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung SyncMaster 713BM
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Scratching clicking noise coming from speakers
maybe you bumped a wire going from computer to speakers.
Are you using the speakers built in the samsung?
try another pair of speakers that are connected to the monitor.
Oct 10, 2009 | Computers & Internet
Sound problem
On you screen there are button, which you can change settings on your screen itself , go to the volume control, and just set your volume on your screen higher, note: not on your pc, but on your screen itself.. enjoy the sound
May 25, 2009 | Computers & Internet
Computers & Internet Logo
855 people viewed this question
David Payne
David Payne
