Remove casing for Panasonic SA-DT310
Switch on home theatre system and it almost immediatly turns itself off after displaying F61. I want to investigate problem for my self but am having trouble removing the casing.
  • 1 more comment
  • jos6 Dec 21, 2008
    I cant find out how to remove casing for Panasonic SA-DT310. The fan is damaget and has to be replaced.
  • moravianphil Apr 19, 2009
    i have the same problem. has anyone worked out how to remove the casing yet?
  • TomSchrauber May 03, 2009
    I have also a problem with the fan (it's an T&T MW-410H12S), which is really loud. It seems hard to find an replacement for that fan. Could someone give me a hint, where to get an replacement?
Figured it out. quite simple really.
1. Unscrew the 3 screws at the back that hold the plastic casing on (NOT the one that only go through the metal but the 3 that go through the plastic).
2. you can now slide the side plastic sections of the casing off.
3. underneath these side sections you will see that there is a small section of plastic on each side that can be pushed in which will then enable you to slide off the top part of the casing.
4. underneath the top plastic casing is further metal casing. unscrew the two screws toward the front that will then enable you to lift this inner metal casing off.
Posted on Apr 19, 2009
What I did to solve this problem
1. take off casing as discribed before
2. loosen screw directly behind fan-holding metal sheet which fixes the whole thing to the bottom of the circuit board
3. take out fan with its holding
4. unpeel sticker at the back of fan
5. put on two, three drops of light oil
6. go back to step one in opposite direction
For me worked perfectly...i didnt have some light mechanical oil...therefore I used sunflower oil...worked, too. See, when it goes rancid, then I replace the whole thing.
Posted on Dec 04, 2010
  • jeffsba Aug 18, 2011
    Tried this using a drop of wd40, works perfectly.
    Genius:
  • 1,550 Answers
My friend your problem are the audio amplifier IC´s are damaged because that code is for that
Posted on Oct 09, 2008
I have removed my internal fan and powering on the error i get on the display is F61. So I guess you only have the internal fan to replace :)
Posted on Aug 14, 2010
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Panasonic sa-dt310
Same problem here. In my case, it's a problem with the fan. I solved this (for the time being...) by cleaning the fan.
Howto:
1. remove the 3 screws fixing the cover (at the back of your DT310);
2. the 2 side covers come off easily, but to release the (plastic) top cover, you need to push in the cover at both sides to let it come off the retaining hooks (take a closer look at the side of the top cover, you'll see what I mean);
3. remove the 2 screws holding the remaining metal cover, and move this cover backwards;
4. now you can check, clean or replace the fan.
Putting it back together should be easy now. ;-)
Oct 19, 2007 | Audio Players & Recorders
1,076 people viewed this question
 Grubhead
Grubhead
