Question about ATI RADEON X1650 Graphic Card
Partial bootup my system-acer aspire sa90- 2gb memory- 580w powerpack problem- when i switch on the acer screen comes on, the verifying dmi pooldata flashes and the microsoft green bars appear, then i have either a black screen,a white screen or black/white, red/white,green/white or yellow/white vertical bars, ive removed the card and reinstalled the original on board graphics and everything is perfect, ive taken out the battery for 10mins to reboot the bios, and ive taken it back to factory settings using the onboard and dvd disc reinstall facility but still no good, if i switch off at the tower on button and switch back on it usualy boots up ok , but on occasions it takes two or more tries- can anyone help please
    Problem Solver:
  • 5 Answers
It seems to be a defective card since one of my old graphics cards was defective and had the same problem. Also, try reinstalling the graphics drivers.
Posted on Oct 12, 2008
Computers comes on and it goes to verifying dmi pool data and comes back with error msg....or after its been unplug for awhile it goes back to normal but after awhile it freezes up and then when hard reset...
During the verifying dmi pool data stage of boot, the Motherboard is trying to 'poll' the devices in your PC. This is governed by the BIOS settings in the CMOS chip. It is possible to have a defective CMOS chip, but rare. It is possible to have invalid or corrupted BIOS data in the CMOS chip--which can be cleared to a 'default' state. You stated that if it is unplugged for a time, that it will 'go back to normal', the corruption is being reset. If your BIOS is set to be 'shadowed into memory' for faster loading, then Disable that feature and see if the problem is corrected.
You would need to open the Tower and locate the Motherboard Model (like P5SD2-VM) then look on the internet for the Manual for that model and see if there are any BIOS settings for the 'shadowing' of the BIOS.
This problem can also occur if there are SATA drives in the Tower and 1 or more are not being detected, (depending on the BIOS MFR,) this happens to older boards with SATA ports, much more than late model ones; so while you have that side-panel off, remove and re-connect all of your Power and Data cables to the Hard drives and the Optical drives, (CD/DVD.)
Jul 31, 2011 | Acer Aspire AM1610-U1201A PC Desktop
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspireā„¢ T180 PC Desktop
Acer Aspire X3200 - VIRUS - Won't boot or re-install
it seems like the HDD is not getting recognised , try this might help you get into BIOS setup by tapping delete key or f2 when system turns on , load the defaults settings for bios then try loading OS , if you are getting the same error message that means hdd has gone bad or the cable to the hdd is loose
Jun 29, 2010 | Acer Aspire X3200 PC Desktop
Stuck at verifying dmi pool data
Try restarting in Safe Mode, press F8 at bootup and then either troubleshoot or do a system restore.
Feb 02, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
DMI Pool Data, Acer
You need a higher computer specification for Windows 7.
Acer Aspire T310 is design only for Windows XP Home/Professional and Windows 2000 according to Acer Support Page:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT310/AspireT310sp2.shtml
Jan 20, 2010 | Acer Aspire T310 PC Desktop
Wont start up grey screen with warning verifying dmi pool data on my desktop pc which is acer aspire
well varifying DMI pool data is not a warning its a process where your system hangs. install new windows or repair the old one.
Jan 07, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
Computer says something about verifying pool data
If it says something along the lines of verifying dmi pool data then you might have a problem with your BIOS ( the setup utility you refer to ). Here is a URL that describes a solution to this problem, it is pretty intense if you don't have at least above average computer skills - http://www.duxcw.com/faq/computer/dmi.html. Let me know if you need any further assistance with this.
Serge C.
Mar 30, 2009 | Acer Aspire T180 PC Desktop
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Jan 06, 2008 | Acer Aspire T310 PC Desktop
ATI RADEON X1650 Graphic Card Logo
213 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
