Question about Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100 will not print
Our printer is networked and last week suddenly stopped printing.
It could be coincidence but it was around the time that the server had just been rebooted.
When a print job is sent so far as Windows is concerned it has printed.
If the Printers window is open from the control panel you can see the job spooling, printing, deleting in the jobs list and the printer light flashes once when the job is sent but the printer remains dormant.
You can ping the printer and it is there.
From the menu you can print a test page fine.
It says the imaging unit and transfer unit need replacing - would this cause it to just stop working? The fact that the test page prints ok suggests to me that they are still alright at the moment and I don't want the expense of buying new ones if the printer will still not work.
We have restarted the print spooler and I contacted Xerox who advised me to disconnect it for 5 mins and that would sort it! - needless to say it didn't.
Any ideas would be greatly appreciated.
  • hobbitt286 Oct 15, 2008
    Thanks for your response, I had a nasty feeling that might be my only option. Thanks for the warning about the memory too. Now to see if it works........
  • hobbitt286 Oct 20, 2008
    Well, I have replaced both units but there is no change. Having now forked out for the parts it is even more important to get this up and running - any more suggestions PLEASE!
    President:
  • 2,072 Answers
Yeah you need to replace that imaging and transfer units for it to print. That has a counter on it and once it comes up with that message it will not print anything.
NOW THE WARANING. Once you replace the unit. Everything you have sent is in the memory and will print out.
What you will want to do is once it starts printing, continue to cancel the jobs until they are all out of memory. Believe me, the jobs are there....
Posted on Oct 09, 2008
  • 2 more comments
  • Rick Kasper Oct 20, 2008
    Let me do some research, I will get back to you.
    Just curious. What happens when you hook something via USB cable?
    Just curious , Are you behind a firewall? And have you tried turning it off. A printer can be pinged but not print behind a firewall. The firewall will stop the print data transfer. Just things popping in to my mind right now . Try setting it up direct via a USB and see if that works and turn off or do a write around with your IP address on the firewall.
    Have you tried looking at your printer through your browser? Open internet explorer or firefox and type in your printer IP address in the adress bar, when you do that does the printer information and setup page come up?
Printer all of a sudden stopped printing, (LED screen out so unable to read errors). Everything was working fine and then it just stopped printing any more jobs, the red light was on the control panel and...
The inverted, blank, or garbled display is pretty common, a new control panel will fix that and is super easy to install and no tools required. Here is a video that shows how.">
Jul 04, 2010 | Xerox Phaser 8550DP Printer
Xerox Phaser 6100 vs Windows 7
Try using the Vista driver, it may work and may not have all the functions that was available under Vista.
Jun 10, 2010 | Xerox Phaser 6100/BD Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Xerox phaser 6350 has stopped printing on two sides. Have document which did print correctly two weeks ago, now does not.
you need to change the settings again on the printer driver itself:) when printing choose the printer and the settings under printer properties
Nov 20, 2009 | Xerox Phaser 6350/YDT Laser Printer
Priner problem
This is likely to be a dirty lens on the laser unit in the base of the printer.
Dec 19, 2008 | Xerox Phaser 3200MFP/N Laser Printer
My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Dec 11, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 8560 Will Not Power On
The 8560 has a one year warranty. Call 1-800-835-6100 and they will come out and fix it.
Aug 07, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Network Printing Issues
Hi alexredfern, Have you checked that the printer is set to be the default printer on the problem PC?
Nov 14, 2006 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
312 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
