I have a canon bjp 3000 and it is showing a 7 orange light flash and will not respond to and anything
  • 2,712 Answers
Try the following steps to reset printer:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Should that fail, unplug the printer from AC power source (wall socket) and from PC. Wait about 5 minutes, replug and reconnect to PC and power on.
If even this does not work, there is a problem with the printer's logic board, and you will either need to get it serviced, or buy a new one (whichever works out cheaper for you...)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Posted on Oct 09, 2008
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Hi, My Canon BJC 3000 printer has the orange light flashing 7 times, followed by 1 green light. What does this mean and How can I fix it?
7 orange followed by 1 green means Cartridge Error.
If you have recently replaced the ink cartridges then please check that they are installed properly and re-seat them if necessary.
If you have not recently replaced your ink cartridges then check the ink levels using the software that came with the printer.
Try replacing the ink cartridges and if that does not solve the problem then you can contact Canon support.
The details for Canon support in the UK can be found here:
Or in the USA:
Please rate my answer if this helps.
Many thanks,
Mar 12, 2011 | Canon BJC 3000 InkJet Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Canon PIXMA iP1000 Printer - don't work
Feb 04, 2009 | Canon Office Equipment & Supplies
Printer Not Responding, 7 orange flashes
Don't replace the print head soooo fast...
Take the print head out first and clean the gold contacts...
I used a very fine sandpaper like emery cloth...
You might get 4 yellow blinks after that.
That is because the printhead was turned upside down to clean and the ink looked low and/or out.
Just wait a few minutes after cleaning and reset...
Mine worked fine after that.... smile....
Aug 09, 2008 | Canon S900 InkJet Printer
Orange lights (3)
Three orange flashes between green indicates a paper jam on this model. Look closely in the paper feed area and the paper exit area for any torn scraps of paper. Also open the top and check in the platen area (where the print head moves back and forth). If you don't see anything, it's possible that a sensor has broken or gone bad.
Jun 11, 2008 | Canon BJC 3000 InkJet Printer
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
