Click to start program. Up comes first screen for seconds then closes to Microsoft error. Fault on operation of DVBTAP.exe. Invites sending error to Microsoft. Big deal. Return Email tonygc2007@bigpond.com Program is WinFast DTV2000 H Machine is running Windows XP pro SP3
    President:
  • 2,712 Answers
There are a lot of headaches and bugs in the SP3. Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation and operation of software.
1. Open the Windows Control Panel.
2. Open the Add / Remove Programs window.
3. Locate the listing for the software and remove it.
Next, do the following:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Another option would be to uninstall the SP3 update and revert back to SP2. You can uninstall the SP3 update in the same way, through Add/Remove Programs in Control Panel.
Hope that helps...Should you have any further questions, please feel free to post them here.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 09, 2008
I have a Dell Inspiron 6000 with windows XP, McAfee Security Suite, and a Verizon USB for internet. When I turn it on I get an error message: dlbcserv.exe has encountered a problem and needs to close. ...
This error message is a result of your Dell printer software functioning improperly.
This is a 'quick fix' to get rid of the error message:
  1. click 'Start'->'All Programs'->Startup
  2. Right click on dlbcserv.exe and click 'delete'
PS: dlbcserv.exe is a Windows process installed alongside Dell Photo Printers and provides additional configuration options for these devices. Although it is not an essential process for the operating system, you should not remove & uninstall it unless it is causing serious problems and errors.Dlbcserv.exe is a Windows file created by Dell. The file is usually found in Program Files\Dell Photo Printer 720\dlbcserv.exe folder. If you find it anywhere else, Please note that dlbcserv.exe could be a virus, trojan, worm, or spyware. Scan your computer with an antivirus software to make sure it is not infected.
Aug 10, 2010 | Dell Inspiron 6000 Notebook
Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
0x71ab664d reference
explorer. exe is a virus or spyware. install any spy ware remover you know on your system and scan the system to remove the malicious ware
Aug 08, 2009 | Microsoft Windows XP Professional
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Explorer.exe Application error in Windows XP Professional SP2
hello ! what you should do put another HD then install XP the reason for this messages could be due to registry .
if you are getting the same messeges get another cd of XP
GOOD DAY
May 27, 2009 | Microsoft Windows XP Professional
WINDOW CANNOT FIND GPHONE.EXE
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:\windows\system32).
Go to this website if you need further removal instructions:
http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
Jan 21, 2009 | Computers & Internet
Windows cannot find 'gphone.exe'
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Missing MSIEXEC.EXE
Try this:
To unregister and re-register Windows Installer:
Click Start, and then click Run.
Type in the Open box: msiexec /unregister and then click OK.
Type in the Open box: msiexec /regserver click OK.
Feb 17, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
