Question about Jane Powertwin Azulon Stroller
Rear brake rubbing on casing
My powertwin rear brake bar has the 2 metal bits that slot intoi plastic casing on wheels. trouble is my right side rubs constantly on casing and makes clicking sound which increases in volume and vibrates slightly when more weight/pressure is put on it. any ideas so i can fix it?
  • 1 more comment
  • 7dixons Oct 09, 2008
    This sounds alot like the problem we have - are your back wheels splaying out aswell? I will be watching this with interest to hear your replies.
  • tasha_1979 Oct 09, 2008
    a little yes. problem solves slightly if you lift pushchair when pushing, suppose it takes the weight off, but not ideal when you have 2 kids and shopping!
  • dubeczattila Feb 01, 2009
    Did anybody have a solution for that? Please write me:
    dubeczattila@gmail.com
  • 3 Answers
We have the same problem. :(
Posted on Oct 17, 2008
Loud metal noise from right rear wheel Volvo v70
If they're drums could be rust on the drum rubbing on the backing plate, or a loose brake component rubbing inside the drum.
Mar 18, 2015 | 2001 Volvo V70
Burning plastic smell from drivers side rear wheel
pull off wheel and check brake pads low,caliper sticking ,or debris -if brakes look good than check hub-wheel bearing----- may be going bad
Apr 11, 2014 | 2005 Honda Accord
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
I have a jane powertwin pro and the rear bar that hangs above the clogs for the rear brake constantly rubs on the cogs making a grinding noise with or without kids in it. Please help
This sounds like either your brake bar is loose or has been bent out of shape. Look at the silver metal pins that click into the black cogs (on the inside of the back wheels), if these are not horizontal, then your brake bar has probably suffered some stress, causing the bar to bend and the pins to touch the cogs.
If the metal pins are totally horizontal, then your brake bar is just probably loose and needs removing and re-rivetting on tighter.
Either way, I would suggest that you contact (if in the UK) this link:
www.johnstonprams.co.uk
who will be able to assist with the repair. You can also take this back to the retailer and arrange a repair through them.
I hope this helps.
Sep 29, 2009 | Jane Powertwin - Silver Jogger Stroller
Jane powertwin splayed back wheels-rear brake plastic bracket
This sounds like some kind of excessive weight on the handle bar or a buggy board has been used, either that or too much pressure has been applied to the break bar. On the break bar, this should have a natural curve to it, if this looks wonky, then this is probably the reason. If this is the case, then the bar will have to be drilled off, straightened and re-rivetted back on.
I would suggest that you contact either your retailer for repairs advice, or www.johnstonprams,co.uk please note that this does sound like you will have to pay for it to be repaired.
I hope this helps.
Aug 15, 2009 | Jane Powertwin Azulon Stroller
I have the older style Jane Powertin with the spoke wheels. The brake bar is hitting off the plastic ring on the inner side of the wheel (that the brake bar fits into when the brake is on)  so when I...
This sounds like the brake bar (at some point) has had a little too much pressure applied to it. The brake bar itself has a natural curve and when too much pressure is applied, the curve becomes distorted, therefore making the silver metal pins sit at an odd angle (instead of being horizontal) this in-turn makes the pins contact the cogs on the inside of the back wheels, hence the clicking noise.
The remedy for this is get the brake bar drilled out (is attached via rivets, so this is the only way) then the bar can be straightened and re-rivetted on. The best option to get advice on this is to contact www.johnstonprams.co.uk or www.jane.es for repair agents.
I hope this helps.
Jun 25, 2009 | Jane Powertwin - Silver Jogger Stroller
Brakes
Yep sounds about normal. Quiet is fine when it gets loud or pronounced then you may have dragging issues. But it sounds like your O.K.,,,
Nov 10, 2008 | 2007 Maico 500 Enduro
Rear foot brake
seems to be a problem of this pram :( let me guess.. left side?! *g*
we just fixed it with cable strap (i can upload a photo if you need).
Sep 06, 2008 | Jane Powertwin Azulon Stroller
1995 chrysler cirrus
jack up the rear wheel and spin the rear wheel to find out what the rub is. look to see if there is any rubbing marks on or in the fender well.( do not have on the emergency brake) Also if the noise could be metalic then it could be the brake drum rubbing on the backing plate.
May 30, 2008 | 1995 Chrysler Cirrus
Jane Powertwin Azulon Stroller Logo
233 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
