Question about Zanussi ZWF1440 Front Load Washer
Zanussi jetsystem 1400 door seal
How do I remove the door seal on my zanussi 1400 ?
The inside of the seal is really dirty & it will have to come out to clean it properly.
Pleas help
Tim
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Posted on Oct 09, 2008
What does fault code e30 on a zanussi jetsystem 1400
Activated anti-flooding device. Try to find leaks in the bottom of washing machine.
Dado
Aug 08, 2014 | Zanussi Washing Machines
I have a Zanussi Jetsystem 1400 7kg washing machine it keeps coming up with a lock on the error screen and won't start for me
have you checked to see if child lock is enabled? does the door lock when start button is pressed?
Apr 10, 2014 | Washing Machines
Zanussi jetsystem 1400- error e90
e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
921 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
