Question about Bosch Dishwashers
Dishwasher switched itself off during cycle - no power now
My S9J1B Bosch dishwasher stopped working during a cycle. I cleared some pips out of it and it started to work again. However yesterday I cleaned the dishwasher with bleach to remove dirt and started a new cycle, but it cut out after about half an hour (I think) and there was about half an inch of water at the bottom. There is now no power to the dishwasher. I have removed the water. Does anyone know how I can get the dishwasher power to come back on? None of our light switches are off so it hasn't tripped the electicity in the house - just the dishwasher.
  • 1 more comment
  • LeeAnn Olivier
    LeeAnn Olivier Oct 09, 2008
    Thanks for getting back!
    After I cleaned out the pips, I was able to do run a complete cycle with dishes successfully. However because I had allowed some mould to grow inside, I then cleaned it with bleach. It was on the second cycle that it cut out completely (no lights on the buttons).
    I'm looking to get someone in to help (so expensive) as I was happy to troubleshoot (remove pips etc) when there was dishwasher power, but now that there's none I may have to hand it over. When it comes to electricity it gets scary. I have no idea bow to get it to come back on again - the dishwasher is built into a cupboard.
  • Anonymous Mar 24, 2014
    no power stopped during cycle, no lights
    stopped half way through cycle, no lights no power
    Problem Solver:
  • 7 Answers
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Posted on Oct 09, 2008
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
Bosh washer won't stop? model SGS45C02
major recall of bosch dishwashers. recommend you check the list.
Jan 01, 2018 | Bosch SGS45C02 Dishwasher
3 hour cycle - dishes not clean - bosch dishwasher
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
Dishwasher2_bing.gif Maintenance
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 18, 2010 | Bosch 24 in. SHV46C13UC Free-Standing...
De Dietrich dishwasher model DVF300JU2 Child opened door during wash cycle closed door but m/c did not restart,now all lights on! unable to clear/restart, tried to cancel programme by pressing 'Start' for...
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Jul 12, 2010 | De Dietrich Dishwashers
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Opened door on cycle, will not continue cycle after closing door
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Apr 16, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
Bosch dishwasher has water in bottom after cycle is complete
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
686 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
