Question about HP Photosmart 7450 InkJet Printer
Constant flashing red light after changing ink
I have changed the ink cartridges but I now have a contant flashing on/off button and a picture of an ink cartridge on the display. I have very little knowledge of technical things so would appreciate an easy to follow solution. Much appreciated Helen
  • Anonymous Dec 02, 2008
    i changed the ink cartrige and now have a flashing red light no matter what i do
I've had the same problem. Take out the cartridge and wipe the copper strip gently with alcohol. Not a lot of alcohol. Just enough to wipe off any dirt. Or, unplug the printer for a few minutes and then plug it back in to reset the memory. The error message you are getting is for a dead cartridge. Take it back and get a different one. Even if it's filled, it can still be dead. There's a micro chip in the cartridge that's suppose to prevent refilling of cartridges. I have had no luck going to Walgreen's. Go to the store and buy boxed refilled cartridges or go to inkhets.com . Don't try to do it yourself. Not worth the hastle.
Posted on Feb 06, 2009
Excellent advice. Turned out to be the cartridge after all. Many thanks.
Posted on Feb 19, 2009
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Jan 24, 2009 | Epson Stylus Photo 810 InkJet Printer
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Ink warning light
often tho they seem the same the alingment of the nozzles dont match, so check alingment most printers offer you a programme that will do this for you...
Aug 18, 2007 | Epson Stylus Photo R800 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
266 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
