Question about Hotpoint NBXR463EBWW Electric Dryer
Hotpoint dryer tdl32
Turn on dryer and drum does not turn - how do i check to see if the belt is broken
  • jue1966 Oct 09, 2008
    thanks - just had a quick peep inside and the belt is missing completely - will order new one today and when arrived will wonder how the hell to fit it haha.
  • 417 Answers
You may be able to check the belt by turning the machine over onto its side so you have access from underneath, if this does not work you will have to remove the back panel of the machine. This is usually done by removing a number of screws which fix the back to the frame of the drier then when have removed the back you should be able to access the belt. remember to disconnect the drier from the electricity supply before you start to do either of these.
Posted on Oct 09, 2008
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
Tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Jul 29, 2012 | Hotpoint Dryers
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
The dryer gets hot but the drum does not turn
sir please check the motor is running and this will be fixed inside the dryer and a belt will be fixed which makes the drum to rotate when the motor starts.so you should check both the belt and the motor.
Sep 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
Tumble dryer drum won't turn
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
Jul 06, 2009 | Dryers
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint vtd00 just replaced the belt for 3rd time put kids clothes into dry and loads of smoke and burning any clues?
Sounds like the motor is turning but the belt is not so, the belt is just setting there burning. You should be able to turn the drum by hand, check the drum rollers and the belt tension roller.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Electric dryer
It may be a broken drive belt, check underneath for remnants of the belt.
Oct 03, 2008 | Hotpoint NLL113EYWO Electric Dryer
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
151 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
