My program dial just keeps spining and the drum is full of water and my cloths
    Sergeant:
  • 351 Answers
Hi is the machine pumping out the water check for a blockage
Posted on Oct 09, 2008
Hi, I have a problem with machine siemens extraklasse f1000. Centrifugation is malfunctioning, the drum keeps spining slowly, and I can't extract the clothes...
Open the drum then disconnect the power in the first instance to remove your clothes. Then contact siemens for help.
Oct 28, 2017 | Siemens Washing Machines
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hi i have a Ariston avl 125 and my problem is that i start my machine and i wont stop again.... i just keep on spining ..... it takes in wather but keeps on spining at 2. wash..... hope that you can...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If this is a timer controller type then the contacts or the function to move on is faulty and needs a replacement. The inlet valve works to allow water and then the motor is struck on and not moving to the next cycle. Test the controller to confirm, check with a similar type before you order for one.
Sep 17, 2011 | Washing Machines
Washing won't spin and i have a washing machine full of water , could you tell me how to check the filter ?
First of all you mustt drain the water that is trapped within the drum. So remove the drain pump/ valve and allow the water to flow out - make sure that you have an arrangement to collect water when the drain Hose is removed.
Now the drain pump/valve must be checked clean if there is dirt clogging. Also test the valve for proper functioning. Also check the inlet valve and filter which is on line with the water inlet which can be traced easily. Check the motor, drive , door switch and finally the control board. If after switching on there is no action , inlet filling or spining when water is full, the program controller must be faulty.
May 19, 2011 | Washing Machines
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Detergent build up
try to wash clothes with pre-wash program
Feb 17, 2009 | Candy CN146 Front Load Washer
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
