Question about Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
My Neff dishwasher keeps sticking at different points on the programmes, completely at random. Its integral so I have to keep the door off so that I can manually move the programme on. Am I right in thinking the programmer is on the way out or is there something else it could be.
If it is the programmer would be be more cost effect to by a new dishwasher taking it in to account its 10 years old.
Thanks
Dave
  • Pikey 17 Oct 09, 2008
    It sticks at different points through out the cycle. It happens when the soap is just about to dispensed, when its heating the water and when its rinsing. These are the most common times. Initially it was when the soap was just about to dispensed, as soon as I moved the cycle on the flap opened. Then the problem escallated to different times. Some times it goes through a cycle with no problem. This morning its happened twice, at the washing and heating stages.
    Problem Solver:
  • 7 Answers
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Posted on Oct 09, 2008
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
Sticking programme
This could be a problem with the controller as it is not waiting for water to warm before continuing.
Water element should be checked, as well as the water thermostat switch (which may be stuck on), possibly a substitute timer fitted to make sure you replace the right part.
Jun 06, 2010 | Neff 24 in. S4443 Built-in Dishwasher
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
Aug 03, 2009 | Neff Dishwashers
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff s5946 slimline built in dishwasher. Fills with water, clonking sound in pipe and does not register on programme, although pump working.
if you only hear the clunking sound while the dishwasher is filling then the inlet valve is bad.. i would replace it because if it fails completely you could possibly have a flood..
Feb 20, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Nov 05, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher takes 3 hours, fails to dry dishes
mine has just started to do the same thing.... not sure why :o(
Aug 18, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
627 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Iron
Iron
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
